Position operators and wavefunctions
In summary, the given Hamiltonian can be simplified by using an ansatz for the wavefunction in the form of e^{i(k_y y + k_z z)}\chi(x). After computing the scalar products, the Hamiltonian can be expressed as the sum of three terms: a kinetic energy term, a term involving the magnetic vector potential, and a term involving the square of the magnetic vector potential. By plugging in the given ansatz into the eigenvalue equation of the Hamiltonian, we can solve for the eigenfunctions and eigenvalues. This ansatz simplifies the problem greatly by taking advantage of symmetries in the system.
carllacan
274
Find the eigenfunctions and the eigenvalues of the following Hamiltonian
[itex]\hat{H} = \frac{1}{2m} \left ( \frac{ \hbar}{i} \vec{\nabla}-\frac{q}{c}(0, B_z x,0) \right ) ^2 = \frac{1}{2m} \left ( - \hbar^2 \vec{\nabla}^2-\frac{\hbar q}{ic}(\vec{\nabla}·(0, B_z\hat{x},0) + (0,B_z x, 0)·\vec{\nabla}) +\left(\frac{q}{c}\right)^2(0, B_z x,0)^2\right ) ^2 = [/itex]
Assume the wavefunction is of the form [itex]\Psi(x) = e ^{i(k_y y + k_z z)}\chi(x)[/itex]
The time dependent Schrodinger Equation:
[itex]\hat{H} \psi(x) = E \psi (x)[/itex]
Computing the scalar products we obtain:
[itex]\hat{H} =\frac{1}{2m} \left ( - \hbar^2 \vec{\nabla}^2-\frac{q}{c}B_z x \frac{\hbar \partial}{i \partial y} + \left(\frac{q}{c}B_z x\right)^2 \right ) [/itex]
And we can rewrite [itex]\frac{\hbar \partial}{i \partial y}[/itex] as [itex]\hat{p} _y[/itex], so:
[itex]\hat{H} =\frac{1}{2m} \left ( - \hbar^2 \vec{\nabla}^2-\frac{q}{c}B_z x \hat{p}_y + \left(\frac{q}{c}B_z x\right)^2 \right ) [/itex]
Next I state the time-dependent Shcrodinger Equation:
[itex]\frac{-\hbar ^2}{2m}\vec{\nabla}^2\psi-\frac{q}{2mc}B_z\hat{x}\hat{p}_y \psi+\frac{1}{2m}\left (\frac{q}{c} B_z \hat{x}\right)^2 \psi = E \psi[/itex]
The x that appears along in the Bz term: is it the position operator or an scalar operator with the value x? If its the position operator how does it interact with the wavefunction?
You seem to have any extra "##^2##" power at the end, which is carried through part of your working, though not in the eventual Schrodinger equation. So I guess that's just a cut-and-past typo.
[itex]\hat{H} =\frac{1}{2m} \left ( - \hbar^2 \vec{\nabla}^2-\frac{q}{c}B_z x \frac{\hbar \partial}{i \partial y} + \left(\frac{q}{c}B_z x\right)^2 \right ) ^2 [/itex]
Are you sure you didn't miss a factor of 2 in the middle term?
I don't think there's any need to do that here. Just leave it as a derivative.
[itex]\hat{H} =\frac{1}{2m} \left ( - \hbar^2 \vec{\nabla}^2-\frac{q}{c}B_z x \hat{p}_y + \left(\frac{q}{c}B_z x\right)^2 \right ) ^2 [/itex]
The position operator acts on these wavefunctions simply as multiplication by ##x##. But you don't need to add the explicit hat on ##x## for this exercise.
You've been given an ansatz for the solution, so just plug that into the Schrodinger equation. (Leave ##x## and ##\partial/\partial y## as they were). The solution method for this type of partial differential equation is just standard separation of variables. (If necessary, look that up on Wikipedia to see a sketch of the general idea.)
Likes 1 person
Yes, its a typo, thank you.
I think not. Isn't this correct?
## \frac{1}{2m}\frac{\hbar q}{ic}(\vec{\nabla}·(0, B_z\hat{x},0) + (0,B_z x, 0)·\vec{\nabla})##
## \frac{1}{2m}\frac{\hbar q}{ic}((0 + \frac{\partial}{\partial y}B_z\hat{x} +0) + (0 + B_z x\frac{\partial}{\partial y} + 0))##
## \frac{1}{2m}\frac{\hbar q}{ic}((0 + 0 +0) + (0 + B_z x\frac{\partial}{\partial y} + 0))##
[itex]\frac{1}{2m} \left (\frac{q}{c}B_z x \frac{\hbar \partial}{i \partial y}\right)[/itex]
It turns out that the differential equation is not differential on the wavefunction; I can make ##\psi## disappear by multiplying by ##\psi^*## on the right on both sides (and assuming it is normalized). However I am left with derivatives of ##\chi(x)##, should I next try to solve for ##\chi(x)## so that I obtain a closed form of ##\psi^## ?
Thanks for your help.
[corrected!]
You must be careful with operators. You always have to make sure to apply the entire expression to the wave function. It's easier to first work it out in the abstract formalism. Here we have
[tex]\hat{H}=\frac{1}{2m} \left [\hat{\vec{p}}-\frac{q}{c} \vec{A}(\hat{\vec{x}}) \right]^2.[/tex]
Multiplying this out gives
[tex]\hat{H}=\frac{1}{2m} \hat{\vec{p}}^2 - \frac{q}{2mc} (\hat{\vec{p}} \cdot \hat{\vec{A}} + \hat{\vec{A}} \cdot \hat{\vec{p}}) + \frac{q^2}{2mc^2} \hat{\vec{A}}^2.[/tex]
Now applying this to the wave function in position representation this translates into (setting [itex]\hbar=1[/itex])
[tex]\hat{H} \psi(\vec{x})=-\frac{1}{2m} \Delta \psi +\frac{\mathrm{i} q}{2mc} (\vec{\nabla} \cdot \vec{A}) \psi+\frac{\mathrm{i} q}{mc} \vec{A} \cdot \vec{\nabla} \psi +\frac{q^2}{2mc^2} \hat{\vec{A}}^2.[/tex]
Since you work in the Coulomb gauge for the vector potential of the magnetic field the 2nd term vanishes identically, and you are left with
[tex]\hat{H} \psi(\vec{x})=-\frac{1}{2m} \Delta \psi +\frac{\mathrm{i} q}{mc} \vec{A} \cdot \vec{\nabla} \psi +\frac{q^2}{2mc^2} \hat{\vec{A}}^2.[/tex]
Now simply plug the given ansatz into the eigenvalue equation of this operator.
You should also think about the question, why one can see from the Hamiltonian, why this ansatz must work out to simplify the problem a lot. Think about symmetries (and maybe even the analogous classical problem about the motion of a spin-0 charge in an magnetic field).
Likes 1 person
[tex]\hat{H}=\frac{1}{2m} \left ( \hat{\vec{p}}^2 - \frac{q}{2mc} \hat{\vec{p}} \cdot \hat{\vec{A}} + \hat{\vec{A}} \cdot \hat{\vec{p}} + \frac{q^2}{2mc^2} \hat{\vec{A}}^2 \right ).[/tex]
Where do those ##\frac{1}{2mc}## factors in the second and fourth term come from?
Looking at the next expression you wrote I assume it was a typo and you meant:
[tex]\hat{H}=\frac{1}{2m} \hat{\vec{p}}^2 - \frac{q}{2mc} \left(\hat{\vec{p}} \cdot \hat{\vec{A}} + \hat{\vec{A}} \cdot \hat{\vec{p}} \right )+ \frac{q^2}{2mc^2} \hat{\vec{A}}^2 .[/tex] Am I right?
I don't understand why the third term is ##-\frac{q}{mc} \hat{\vec{A}} \cdot \hat{\vec{\nabla}}## and not ##-\frac{q}{2mc} \hat{\vec{A}} \cdot \hat{\vec{\nabla}}##. I guess its the "factor of 2" strangerep said I missed, but I can't see where it comes from.
Also, I understand the ##\hbar## we get when going from ##\hat{\vec{p}}## to ##-\hbar i\vec{\nabla}## disappears when setting it to unity, but what about the ##i##?
Thanks.
I've corrected my typos (hopefully all). Concerning the factor 2:
[tex]
(\hat{p} \cdot \vec{A}+\vec{A} \cdot \hat{p}) \psi = -\mathrm{i} \left (\vec{\nabla} \cdot (\vec{A} \psi) + \vec{A} \cdot \vec{\nabla} \psi \right ) = -\mathrm{i} \left [ (\vec{\nabla} \cdot \vec{A}) \psi + \vec{A} \cdot \vec{\nabla} \psi + \vec{A} \cdot \vec{\nabla} \psi \right ]= -\mathrm{i} \left [ (\vec{\nabla} \cdot \vec{A}) \psi + 2\vec{A} \cdot \vec{\nabla} \psi \right ].[/tex]
It's just using the product rule of differentiation on the first term.
Likes 1 person
[tex]
Oh, so the del operator acts on ##\vec{A}\psi##, and not just on ##A##. This helps me in a couple of other problems on which I was stuck. Thank you very, very much.
Yes, this is a very common mistake. I guess nearly everybody makes it when learning the operator formalism :-). It is easily avoided by making oneself clear what an "product" of operators means: When writing [itex]\hat{A} \hat{B}[/itex] it means to first apply [itex]\hat{A}[/itex] on a Hilbert-space vector (or a wave function as its representant in the position representation) and then on the result (which is a again a Hilbert-space vector/wave function) the operator [itex]\hat{B}[/itex].
In other words, "multiplication" in the context of operators has the meaning of "composition of mappings".
So... are you (carllacan) able to solve the PDE by separation of variables now?
Likes 1 person
I thought I could, but I just realized that I made the same mistake with the ## \vec{\nabla}\vec{\nabla}## operator that I had made with the ##\vec{\nabla}\vec{A}## operator, so I 'm doing it again, more carefully.
That is, when developing the square of the operators I did ##(\vec{\nabla}[·]+...)^2= \vec{\nabla}^2[·]+...## (I use ##[·]## as a placeholder for the function on which the ops act) when the right result would be ##(\vec{\nabla}[·]+...)^2= 2\vec{\nabla}·\vec{\nabla}[·]+... = ##, right?
carllacan said:
[...] when developing the square of the operators I did ##(\vec{\nabla}[·]+...)^2= \vec{\nabla}^2[·]+...## (I use ##[·]## as a placeholder for the function on which the ops act) when the right result would be ##(\vec{\nabla}[·]+...)^2= 2\vec{\nabla}·\vec{\nabla}[·]+... = ##, right?
If I understand you correctly, that placeholder shouldn't be inside the parentheses.
Why not just write it out first in component notation like this:
$$(\partial_k - A_k)\Big( (\partial_k - A_k) \Psi \Big) ~,~~~~~~ \text{(with implicit summation over the index k)} ~.$$I've written ##A_k## for the components of the vector ##\frac{q}{c}(0, B_z x, 0)##, (and omitted factors of ##\hbar/i## which you can put back in). Then expand it using the Leibniz product rule carefully. Some things should disappear because only ##A_y## is nonzero but depends only on ##x##, hence terms like ##(\partial_k A_k)\Psi## disappear. (Do you see why?)
Yep, you're right.
That's more or less what I'm doing. Though it looks that I also got the ##vec{A}## wrong (its expression in terms of B comes from another excercise which I had doen wrong).
Thank you very much for your help, I'll keep working on this.
Related to Position operators and wavefunctions
1) What is a position operator?
A position operator is a mathematical operator that determines the position of a particle in a given space. It is represented by the symbol x and is typically used in quantum mechanics to describe the position of a particle in terms of its wavefunction.
2) How does a position operator relate to the uncertainty principle?
The uncertainty principle states that it is impossible to know both the exact position and momentum of a particle at the same time. The position operator is used to calculate the position of a particle, while the momentum operator is used to calculate the momentum. Therefore, the uncertainty principle essentially limits the precision of the position operator.
3) What is a wavefunction and how is it related to position operators?
A wavefunction is a mathematical function that describes the behavior of a quantum system, such as a particle. It represents the probability amplitude of finding a particle at a given position. The position operator is used to calculate the expectation value of the wavefunction, which gives the most probable position of the particle.
4) Can position operators be used for particles with definite positions?
No, position operators are typically used for particles in quantum mechanics, which are described by wavefunctions. These particles do not have definite positions, but rather have a range of possible positions with different probabilities. Classical particles, on the other hand, have definite positions and do not require the use of position operators.
5) How are position operators represented in mathematical equations?
In quantum mechanics, position operators are represented by the symbol x. In mathematical equations, it is typically written as an operator, such as ^x, to distinguish it from a classical variable. The position operator is also used in the Schrödinger equation, which describes the time evolution of a quantum system.
