Positioning of the artificial satellite
  • Thread starter aqua_s
  • Tags
    Satellite
In summary, an artificial satellite is set on an orbit around the earth by using a rocket to lift it into the gravitational field and increase its velocity. The satellite's energy and angular momentum must match the desired orbital parameters. Specific orbits are chosen based on the purpose of the satellite, with some needing to be stationary and others needing to be in a constellation for continuous coverage.
aqua_s
how is an artificial satellite set on an orbit around the earth?
Astronomy news on Phys.org
Well, a rocket.
Can you be more specific?
As DaveC mentioned a rocket is used to 1) lift a satellite radially in the gravitational field, and 2) increase it's azimuthal (centrifugal) velocity. The energy and angular momentum of the satellited at the end of the launch trajectory has to match orbital parameters at some tanget to the desired orbit. A satellite can be maneuvered with thrusters, but bascially, it is a matter of achieving the right orbital parameters for given orbit.
See some basic mechanics here -
http://hyperphysics.phy-astr.gsu.edu/hbase/orbit.html
If the question is intended to be asking how specific orbits are picked, they are based on the purpose of the satellite. Ie, a DirecTV satellite needs to be stationary so that people can point their dishes at it, so they locate the satellites in geostationary orbit. GPS needs several satellites in different locations to give a position, so they use a constellation of around 24 satellites going in different directions to keep a few in view at all times.
thnku for all the answers :-)
FAQ: Positioning of the artificial satellite
What is the purpose of positioning an artificial satellite?
The purpose of positioning an artificial satellite is to ensure that it is in the correct orbit to fulfill its intended function. This could include communication, navigation, Earth observation, or scientific research.
How is the position of an artificial satellite determined?
The position of an artificial satellite is determined using various tracking and monitoring systems, including ground-based radar, GPS, and onboard sensors. These systems provide real-time data on the satellite's location, velocity, and altitude.
Why is it important to accurately position an artificial satellite?
Accurately positioning an artificial satellite is crucial for its proper functioning and longevity. If the satellite is not in the correct orbit, it may not be able to communicate with Earth or gather accurate data. Improper positioning can also lead to collisions with other objects in space.
What factors affect the positioning of an artificial satellite?
The positioning of an artificial satellite can be affected by various factors, including Earth's gravity, atmospheric drag, solar radiation pressure, and gravitational forces from other objects in space. These factors must be taken into account when determining the satellite's orbit and trajectory.
Can an artificial satellite's position be adjusted?
Yes, an artificial satellite's position can be adjusted through a process called orbital maneuvering. This involves using thrusters or other propulsion systems to change the satellite's velocity and alter its orbit. This is often necessary to maintain the satellite's position or to move it to a new orbit for a different mission.
