Positive and negative signs on Work
In summary, the problem involves finding the launch speed of a marble using the force interaction between it and a compressed spring. Chetan is unsure of the process and is asking for help understanding it.
bigsmile
An amount of work equal to 1.5 J is required to compress the spring in a spring gun. ?
Wtotal = change of KE[/B]
W=ΔKE=(1/2)m(Vf² - Vi²)
It sounds like the Vf >0 and would be maximum after the spring is compressed hard and get ready to launch the marble. Hence, the marble will have the maximum launch speed. In that case, Vi of marble = Vf of the spring.
Vi of the spring should be zero. It starts from rest before compression.
But how is the Vi and Vf of the spring help me find the "launch Speed " of the marble?
I may not understand the process of energy transfer and force interaction between the marble and spring. Quite confusing!
I am lost and am unsure where my reasoning is wrong. Need help!
[/B]
What is your understanding of the force interaction between the marble and the spring? Do you know the equation for the force a spring exerts in terms of the spring constant and the displacement of the spring from its unextended length? Can you draw a free body diagram of the marble, showing the forces acting on it while it is in contact with the spring? Based on your free body diagram, can you write a force balance equation for the marble?
Chet
Related to Positive and negative signs on Work
What are positive and negative signs on Work?
Positive and negative signs on work refer to the direction of work being done. A positive sign indicates that the force is acting in the same direction as the displacement, while a negative sign indicates that the force is acting in the opposite direction of the displacement.
How do positive and negative signs on Work affect the value of Work?
The sign of work determines whether the work done is positive or negative. If the sign is positive, the work done is considered to be positive, meaning that energy is being transferred to the object. If the sign is negative, the work done is considered to be negative, meaning that energy is being taken away from the object.
What is the significance of positive and negative signs on Work in physics?
In physics, positive and negative signs on work are important because they help us understand the direction and magnitude of the work being done on an object. This allows us to calculate the amount of energy being transferred and determine the overall effect on the object's motion.
Can positive and negative signs on Work change during an interaction?
Yes, the sign of work can change during an interaction. This can happen if the direction of the force or displacement changes. For example, if an object is lifted from the ground and then lowered back down, the work done will be positive while it is being lifted and negative while it is being lowered.
What happens when the sign of Work is zero?
When the sign of work is zero, it means that there is no net transfer of energy between the object and the force acting on it. This can happen if the force and displacement are perpendicular to each other, or if the force and displacement are equal and opposite in direction, resulting in a net work of zero.
