Positive Definite Matrix - I think this is correct? Just want reassurance.
  • Thread starter Thread starter Chronothread
    Matrix Positive
The discussion centers on determining the values of b for which the matrix is positive definite. It is established that the expression x^T A x is positive for all nonzero x when -2 ≤ b ≤ 2, but b = 2 and b = -2 do not yield a positive definite matrix. The upper left entry must be positive, and the determinant of the upper left 2x2 submatrix must also be positive to satisfy the conditions for positive definiteness. The final consensus is that while the range -2 ≤ b ≤ 2 is correct, the endpoints do not result in a positive definite matrix. The thread emphasizes the importance of checking both the matrix elements and determinants in these evaluations.
Chronothread
For what b is the following matrix positive definite?
(\stackrel{1}{b} \stackrel{b}{4})
(Sorry for the strange way I have that matrix represented)
For a positive definite matrix
x^{T}Ax
for all nonzero x in \Re^n
x^{T}Ax = x^{2}_{1}+2bx_{1}x_{2}+4x^{2}_{2}
And the only time this is a strictly positive number for all x is when b is zero correct?
Thanks!
(Also, if you have suggestions on how I can better represent my math using tex then I am doing please let me know)
No, there are other values of b that make that positive definite. Complete the square.
Ah yes, thank you.
Just to check quick then I get
(x_{1}+bx_{2})^{2}+(4-b^{2})x^{2}_{2}
Which is positive when -2\leq b \leq 2, correct?
Thanks again.
Remember that if A is an n \times n positive definite matrix then, among other things, the upper left element of the matrix must be positive, the determinant of the upper left 2 \times 2 submatrix must have a positive determinant, and so on. For your matrix to be positive definite this means the upper left entry must be positive (check) and the determinant of the matrix has to be positive. What does that fact tell you about b ? (Just an alternate way of considering this type of problem)
Chronothread said:
Ah yes, thank you.
Thanks again.
I wouldn't say b=2 or b=(-2) is going to give you a positive definite matrix.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 31 ·
