MHB Positive Integer Solutions of $(x^2+y^2)^n=(xy)^{2014}$
  • Thread starter Thread starter anemone
    Integer Positive
The discussion focuses on finding all positive integers \( n \) such that the equation \( (x^2+y^2)^n=(xy)^{2014} \) has positive integer solutions. Participants acknowledge contributions, particularly from Opalg, who provided a partial solution deemed correct. A complete model solution is anticipated to be shared for further clarity. The conversation emphasizes the importance of collaborative problem-solving in mathematical inquiries. The thread aims to enhance understanding of the equation's properties and potential solutions.
anemone
MHB
POTW Director
Find all positive integers $n$ for which the equation $(x^2+y^2)^n=(xy)^{2014}$ has positive integer solutions.
Mathematics news on Phys.org
I looked for solutions in which $x$ and $y$ are both equal to the same power of $2$.
So suppose that $x=y=2^k$. Then the equation becomes $\bigl(2^{2k+1}\bigr)^n = \bigl(2^{2k}\bigr)^{2014}$,
$2^{(2k+1)n} = 2^{4028k}$,
$(2k+1)n = 4028k = 4*19*53k$.
Since $k$ and $2k+1$ are co-prime, it follows that $2k+1$ must be an odd divisor of $4028$, namely $19$, $53$ or $19*53 = 1007$. The corresponding values of $k$ are $9$, $26$ and $503$. That gives these three solutions to the problem:
$x=y=2^9, \ n = 4*53*9 = 1908$,
$x=y=2^{26}, \ n = 4*19*26 = 1976$,
$x=y=2^{503}, \ n = 4*503 = 2012$.
That's as far as I can go. I believe that those three solutions should be the only ones, but I can't see how to prove that there are no others.
Thanks Opalg for your participation and the partial solution, which your answer is definitely correct.
I will post the model solution below, I hope you and the readers will enjoy reading the solution.
Assume that $(x^2+y^2)^n=(xy)^{2014}$ holds for some positive integers $n,\,x$ and $y$. From $x^2+y^2\ge 2xy>xy$ it follows that $n<2014$. Let $d=\gcd(x,\,y)$ and $a=\dfrac{x}{d}$, $b=\dfrac{y}{d}$. Then $d^{2n}(a^2+b^2)^n=d^{2\cdot 2014}(ab)^{2014}$, which gives the equality $(a^2+b^2)^n=d^{2\cdot (2014-n)}(ab)^{2014}$. As $b$ divides the right side of this equality, $(a^2+b^2)^n$ is divisible by $b$ as well. But because $\gcd(a,\,b)=1$, also $\gcd(a^2,\,b)=1$ and $\gcd(a^2+b^2,\,b)=1$ whence $\gcd((a^2+b^2)^n,\,b)=1$, so the only possibility is $b=1$. Due to symmetry, also, $a=1$. The above equality now takes the form $2^n=d^{2\cdot(2014-n)}$. Therefore, $d=2^k$ for some $k$ and $n=2k\cdot(2014-n)$, whence $n\cdot(2k+1)=4k\cdot 1007$. Since $\gcd(2k+1,\,4)=1$ and $\gcd(2k+1,\,k)=1$, $2k+1$ divides 1007. As $1007=19\cdot 53$ and $n$ has to be positive, the possible values for $k$ are 9, 26 and 503, and the corresponding values of $n$ are 1908, 1976 and 2012.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
