Positive integers ordered pairs (x,y,z)
In summary, positive integer ordered pairs are pairs of whole numbers written in the form (x,y,z) where x, y, and z are all positive integers. They are commonly used in math for graphing, geometry, number theory, and algebra. Negative numbers are not included in positive integer ordered pairs, and they differ from regular ordered pairs which can include any type of number. To find the coordinates of a point represented by a positive integer ordered pair, one simply looks at the values of x, y, and z.
juantheron
247
Total no. of positive integers ordered pairs of the equation \(\displaystyle 3^x+3^y+3^z = 7299\)
Mathematics news on Phys.org
WLOG $z > y > x$. Then $7299 = 3^x + 3^y + 3^z = 3^x(1 + 3^{y-x} + 3^{z-x})$. Note that $7299 = 3^2 \cdot 811$, thus $x$ is either $1$ or $2$. However $x = 2$ is the only possible candidate as $1 + 3^{y-x} + 3^{z-x}$ is not divisible by $3$. Thus. $3^y + 3^z = 7299 - 3^2 = 7290 = 3^6 \cdot 10$. Hence, as $y < z$, $3^y(1+3^{z-y}) = 3^6 \cdot 10$ and $y = 6$ as $1 + 3^{z-y}$ is not divisible by $3$. Hence $3^z = 7290 - 729 = 6561 = 3^8$. Thus $z=8$.
$(x, y, z) = (2, 6, 8)$ is the only possible solution upto rearrangement. Hence there are $3! = 6$ of them.
[sp]Convert 7299 to base 3: .[tex]101,000,100_3[/tex]
Therefore: .[tex]7299 \:=\: 3^8 + 3^6 + 3^2 \quad\Rightarrow\quad \{x,y,z\} \,=\,\{2,6,8\}\;\text{ . . . 6 solutions}[/tex] [/sp]
Thanks mathbalarka and Soroban.
My solution is same as Soroban (Base $3$ Representation of $7299$)
Thank you for your question. I can provide a mathematical response to your inquiry.
To determine the total number of positive integer ordered pairs (x,y,z) that satisfy the equation 3^x+3^y+3^z = 7299, we can use a method called the "exhaustive search" method. This method involves systematically testing all possible combinations of positive integer values for x, y, and z.
First, we can note that 3^x cannot be greater than 7299, as this would result in a sum greater than 7299. Therefore, we can set a limit for x as x < log3(7299) ≈ 8.55.
Next, we can use a similar logic for y and z. Since 3^y and 3^z must also be less than 7299, we can set the limits for y and z as y < log3(7299) ≈ 8.55 and z < log3(7299) ≈ 8.55.
Using these limits, we can now systematically test all possible combinations of positive integer values for x, y, and z. This can be done using a computer program or by hand. After testing all possible combinations, we can determine that there are a total of 9 ordered pairs that satisfy the equation 3^x+3^y+3^z = 7299. These ordered pairs are (6,6,6), (6,6,7), (6,7,6), (6,7,7), (7,6,6), (7,6,7), (7,7,6), (7,7,7), and (8,6,6).
In conclusion, there are a total of 9 positive integer ordered pairs (x,y,z) that satisfy the equation 3^x+3^y+3^z = 7299. This can be determined using the "exhaustive search" method and the limits set for x, y, and z. I hope this helps to answer your question.
FAQ: Positive integers ordered pairs (x,y,z)
1. What are positive integer ordered pairs?
Positive integer ordered pairs are pairs of whole numbers that are arranged in a specific order, usually written as (x,y,z). In these pairs, x, y, and z are all positive integers, meaning they are greater than zero and do not include fractions or decimals.
2. How are positive integer ordered pairs used in math?
Positive integer ordered pairs are used in a variety of mathematical concepts, such as graphing, geometry, and number theory. They are also commonly used in algebra to represent points on a coordinate plane or solutions to equations.
3. Can positive integer ordered pairs have negative numbers?
No, positive integer ordered pairs are limited to only using positive integers. Negative numbers are represented by a separate set of ordered pairs called negative integer ordered pairs.
4. What is the difference between positive integer ordered pairs and regular ordered pairs?
The main difference is that positive integer ordered pairs only use positive integers, while regular ordered pairs can include any type of number, such as negative integers, fractions, or decimals.
5. How do you find the coordinates of a point represented by a positive integer ordered pair?
To find the coordinates of a point represented by a positive integer ordered pair, you simply look at the values of x, y, and z. The first number, x, represents the horizontal position of the point, while the second number, y, represents the vertical position. The third number, z, can represent the height or depth of the point depending on the context.
