Positron-electron annihilation in matter
In summary, there are differing statements about the dynamics of annihilation when the positron has kinetic energy in different sources. Some sources suggest that the positron must lose its kinetic energy through ionization or bremsstrahlung before it can annihilate with an electron, while others state that annihilation can occur with higher energy photons or heavier particles if the kinetic energy is high enough. However, in the case of positrons used in PET and radioactive decay, they primarily lose their energy through ionization and then combine with an electron to form positronium before annihilating and producing two 0.511 MeV gamma rays. Higher energy positrons require an accelerator to produce heavy particles. The resulting photons from annihilation do not possess electric
seerongo
47
I have seen some seemingly differing statements in various sources about the dynamics of annihilation when the positron has some kinetic energy and is traveling through a medium.
Two sources I've read state or imply that a positron in motion through matter must first lose it's kinetic energy through ionization or bremsstrahlung before it can annihilate with an electron, and even then, only through an intermediate positronium, and will therefore only annihilate with the signature 511 kev photons. Is all this true?
Another source (the Wiki on annihilation) seems to say that annihilations can take place involving higher energy photons or even heavier particles if the kinetic energies are high enough.
So, what really happens with an energetic positron in matter? I'm especially interested in the case of positrons emitted in radioactive decay and the physics behind PET scanning.
Thanks.
Be careful with Wikipedia since it does not have a rigorous control system on the quality of information.
Positrons used in PET are of low energy (keV and low MeV), so they slow down in matter, primarily by ionization. Once they slow down to very low energy, they will combine with an electron (positronium) and then annihilate with the electron, which results in the formation of two 0.511 MeV gamma rays.
15O and 18F, have respective maximum positron energies of about 1,730 keV and 630 keV. Ref: http://hps.org/publicinformation/ate/q6655.html
See also - http://www.np.ph.bham.ac.uk/pic/physics.htm
Radiation Basics — Beta Particles (negative and positive) and Electrons
http://hps.org/publicinformation/ate/q6240.html
Other common positron emitters are:
22Na, 65Zn, 68Ga, and 114In.
http://www.ehs.ucsf.edu/Manuals/RSTM/RSTM%20Chap1.htm#2.%20POSITIVE%20BETA%20PARTICLES
Higher energy positrons must be energized in an accelerator. They will not produce heavy particles unless their kinetic energy is on the order of high MeV or GeV.
As usual, you nailed my question. So, it appears that annihilation can occur either after thermal equilibrium or through positronium on the way down. I need to research positronium, that's an interesting phenomenon in itself. In either case, it's always 2 x 511kev in lower energy situations, which certainly explains the reliable and useful signature. Very curious behavior, I wonder what the explanation is for having to come to rest before annihilation.
I know what you mean about Wiki. I always try to "consider the source," but with Wiki, you don't usually know the source.
Thanks for the reply and references.
Hi...sorry, this may be a closed topic now, but just wanted to know if the photons formed in this anhilation process carry any charge with them ? cause what will happen to the negative charge of electron and the positive charge of the positron ? they are neutralized for the system as a whole, but charges won't be destroyed rt ?
Nope, photons do not possesses electric charge. All that matters is that the total charge of the system be the same (zero) before and after annihilation.
Heitler "The Quantum Theory of Radiation" Third edition (1954) plots the integrated probability of positron annihilation in flight vs. positron kinetic energy on page 385. For a 1-MeV positron, the integrated probability of annihilation in flight (before stopping) is ~4%.
Bob S
Related to Positron-electron annihilation in matter
1. What is positron-electron annihilation in matter?
Positron-electron annihilation in matter is a physical process in which a positron (a positively charged particle) collides with an electron (a negatively charged particle) and both particles are converted into energy in the form of gamma rays.
2. How does positron-electron annihilation occur?
Positron-electron annihilation can occur when a positron and an electron come into close proximity, either through thermal collisions or through the decay of a radioactive material.
3. What are the applications of positron-electron annihilation in matter?
Positron-electron annihilation has various applications in fields such as medical imaging, material science, and nuclear physics. It is used in positron emission tomography (PET) scans, studying defects in materials, and understanding the structure of atomic nuclei.
4. What happens to the energy produced during positron-electron annihilation?
The energy produced during positron-electron annihilation is released in the form of gamma rays. These gamma rays can be detected and measured, providing information about the materials and particles involved in the annihilation process.
5. How is positron-electron annihilation studied in the laboratory?
In the laboratory, positron-electron annihilation can be studied through techniques such as positron annihilation spectroscopy and positron lifetime spectroscopy. These techniques involve using detectors to measure the gamma rays produced during annihilation and analyzing the data to understand the properties of the materials being studied.
9K
