Positron Helix magnetic field, find pitch and radius
In summary, a positron enters a uniform magnetic field at a speed of 5.40 x 10^6 m/s with an angle of 85.0° to the x-axis. The particle's motion is expected to be a helix. To find the pitch of the trajectory, vx is multiplied by the period, which is found to be (2πm)/qB. To find the radius, the velocity in the y and z directions are assumed to be equal and then plugged into the equation r = (vm)/qB.
JosephK
40
A uniform magnetic field of magnitude 0.137 T is directed along the positive x axis. A positron moving at a speed of 5.40 106 m/s enters the field along a direction that makes an angle of θ = 85.0° with the x-axis (see figure below). The motion of the particle is expected to be a helix.
(a) Calculate the pitch p of the trajectory as defined in figure.
(b) Calculate the radius r of the trajectory as defined in figure.
vx = sqrt(vy^2 + vz^2)
R = (m (vx) )/ qB
T = (2 pi r ) / vx
To find vx multiply v vector by sin(5 degrees). Plugging in values to radius. Answer is significantly wrong. To find pitch, p = (vx)T = 2 pi r.
Likes Issy
I understand this problem now. Since the magnetic field is directed in the x direction, the magnetic force is not directed in the x direction. Thus, acceleration in the x direction is zero. And so, velocity in the x direction is constant. We obtain velocity in the x direction by multiplying velocity vector by cos 85 degrees. We now find the period. It follows that the period is the circumference of the circle divided by the velocity of the particle. Replacing the velocity by the equation v = qBr/m, the period is equal to ( 2 pi m ) / q B. Consequently, the pitch p is equal to the velocity in the x direction times T.
Now we solve part B. We assume that velocity in the y direction is equal to the velocity in the z direction. Then, velocity in the y direction is equal to the velocity vector times sin 85. Then, by equation, r = (v m) / qB, we find the radius.
Likes Issy
FAQ: Positron Helix magnetic field, find pitch and radius
1. What is a Positron Helix magnetic field?
A Positron Helix magnetic field is a type of magnetic field that is created by the motion of a positron, which is the antiparticle of an electron. This field is characterized by a helical shape, similar to a corkscrew, and is commonly found in high-energy physics experiments.
2. How is the pitch of a Positron Helix magnetic field determined?
The pitch of a Positron Helix magnetic field is determined by the speed and energy of the positron, as well as the strength of the magnetic field it is moving through. The higher the energy and speed of the positron, the tighter the helical shape and the smaller the pitch of the magnetic field.
3. What is the radius of a Positron Helix magnetic field?
The radius of a Positron Helix magnetic field is the distance from the center of the helix to the outermost edge. This can vary depending on the strength of the magnetic field and the energy of the positron, but it is typically on the scale of micrometers.
4. What factors can affect the pitch and radius of a Positron Helix magnetic field?
The main factors that can affect the pitch and radius of a Positron Helix magnetic field are the energy and speed of the positron, as well as the strength of the magnetic field it is moving through. Other factors, such as the presence of other particles or external forces, can also have an impact on the shape and size of the field.
5. How is the Positron Helix magnetic field used in scientific research?
The Positron Helix magnetic field has many applications in scientific research, particularly in high-energy physics experiments. It can be used to study the behavior of positrons and other particles in strong magnetic fields, as well as to create and control plasma in fusion experiments. It is also used in medical imaging techniques, such as positron emission tomography (PET), to study the structure and function of organs and tissues in the human body.
