andrewr
- 263
I have been studying QM and am interested in keeping to the non-relativistic theory for now.
In many experiments of crossed gamma rays in the vicinity of a massive particle (or nucleus), pair generation of an electron and its anti-particle the positron is well described.
In some instances, the electron generated will begin forming an orbital with the positron as a temporary nucleus/atom analogy, but in a short fraction of a second annihilation happens.
There are clearly spin states that cause the lifetime to be extended, as well as the possibility of higher energy orbital transitions delaying the decay. So that normal QM orbitals that one would expect in hydrogen, albeit with different energies than hydrogen, appear to be possible.
In basic QM theory, using the NR Schrodinger equation, usually assumes a massive hydrogen nucleus at the origin -- and the 1S orbitals (ground state) can be worked out easily. In some problems I have observed, the reduced mass is used to aid resolving finer details but having a reduced mass does not in and of itself prevent the diffusion of the electron around the nucleus in accordance with HUP. Sometimes I hear it said that that HUP prevents the electron from "falling" into the nucleus;
Without appealing to the subatomic theories, or relativity, how would one know from just basic QM (NO QCD, QFT, etc). that positronium is not protected from collision by HUP. That is, there clearly will be a reduced mass which will be dead center between the identical mass particles, m/2, but is there a (easy) way to identify where the basic Schrodinger Equation breaks down such that decay happens?
eg: is there a momentum measurement that one can make on the positronium pair that would indicate these two oppositely charged particles have velocities too high to be treated by the non-relativistic Schrodinger equation?
I know the velocities in Gold, cause such a problem, but is that true of positronium?
If not, what is the essential difference based on mass -- which is the only difference that I can identify that would affect basic Schrodinger equation solutions -- that would cause these two particles to be able to get close enough (enough of a probability field) that they could collide?
