Possibility of multiple moons in Earth-Moon system
In summary, it is unlikely for the Earth to have multiple moons, and even if it were possible, it would be unstable due to perturbations from the Sun. The formation of regular satellites from ancient massive rings is also unlikely to result in a multiple satellite system for Earth. There is no known maximum mass for moons in a 1:2:4 orbital resonance, but it is unlikely that our moon is too massive to allow for other satellites to exist in this resonance due to its own significant perturbations. Some simulations and calculations are needed to determine the stability and possible resonance of multiple moons around Earth.
Qshadow
27
I am interested in theoretical (what if) possibility of our Earth having more than one moon,
I wonder if they can be arranged at the same orbital resonance as the Galilean moons 1:2:4
If yes, would such system be stable?
If yes, should our Moon be the first, second or third satellite out of the three for the system to be most stable?
Assuming such system is possible and stable,
I have made some calculations based on the assumption that our Moon is second (Moon2), and using the Kepler's Third Law, for calculating the distance of all the moons as function of the orbital period T (see Orbital Period wiki):
Moon1 distance: (((27.3*24*60*60)^2*398600)/(16*3.14^2))^(1/3) = 241,000 Km
Moon2 distance: (((27.3*24*60*60)^2*398600)/(4*3.14^2))^(1/3) = 383,000 Km
Moon3 distance: (((27.3*24*60*60)^2*398600)/(1*3.14^2))^(1/3) = 608,000 Km
is this correct way to do this, or am i missing something, and this is not the way to calculate this distances?
If no, please point me to correct info,
Thanks,
Qshadow.
Astronomy news on Phys.org
Looks fine. Although you didn't have to use all those numbers. It's much easier to just use ratios:
In units of Lunar month and Lunar orbital radius, you can just write:
##a=\sqrt[3]{T^2}##
which will net you the ratio of Lunar orbital radius. E.g., for ##T=2## you get a=1.59 (of the radius), which is about 608 Mm.
This paper:
Formation of Regular Satellites from Ancient Massive Rings in the Solar System
suggests it being unlikely for Earth to form a multiple satellite system. At least as a result of accretion from ring material.
The specific question of the most stable configuration I won't be able to answer, sorry. Naively, I'd think if it works for Jupiter...
...it is not allowed for ox.
But Moon is pretty far out and therefore strongly perturbed by Sun. Satellites outside Moon would therefore be expected to be in trouble.
Thanks Bandersnatch, your representation is much nicer indeed.
Bandersnatch said:
the paper is very interesting, it will take me some time to swallow it.
This is something that I was afraid of, but without some simulation or numerical calculation I can't know for sure.
Also, for the 1:2:4 orbital resonance rule, what is the maximum possible masses of the satellites that satisfy such rule? can it be that our Moon is too massive to allow for other satellites to exist even if they try to follow this orbital resonance?
More moons are problematic. Our moon is very massive compared to earth, so it will disturb other orbits significantly.
The outer border for moons is given by the hill sphere. I don't think you can fit a stable orbit between moon and the outer region of stability for Earth satellites.
Stable low Earth orbits (far away from the moon) are easy. Resonances I don't know. The orbit of moon is not circular, and changes its orientation over time due to perturbations from the sun. It would be tricky to fit a resonant orbit in that I think.
Charon is even more massive, but is resonant with Nix and Hydra. Yet these are from 1:4, not closer in or inside Charon orbit.
I replied to your post on my forum with suggestions on how to use Gravity Simulator to answer your questions:
http://www.orbitsimulator.com/cgi-bin/yabb/YaBB.pl?num=1422283773/0#3
The Earth being so close to the Sun is the problem. Semantics, I admit, but it's hard to get moons around planets close to the Sun because you don't have to be very far out before the Sun becomes a problem. The Earth is lucky to have even one moon.
Or unlucky. The Earth obtained a moon by having one collide with it.
FAQ: Possibility of multiple moons in Earth-Moon system
Is it possible for the Earth to have multiple moons?
Yes, it is possible for the Earth to have multiple moons. In fact, some scientists believe that Earth had multiple moons in the past, which eventually merged to form the single moon we have today.
How many moons can the Earth support?
The Earth can theoretically support multiple moons, as long as they are in stable orbits and do not collide with each other. However, the exact number of moons that the Earth can support is still unknown and would depend on various factors such as the size and distance of the moons from Earth.
What would happen if the Earth had multiple moons?
If the Earth had multiple moons, it would significantly impact the tides and the Earth's rotation. The gravitational pull of the additional moons would cause more complex tidal patterns, and the Earth's rotation may become unstable. Additionally, the presence of multiple moons could also affect the Earth's climate and potentially lead to changes in the planet's habitability.
Are there any other planets with multiple moons?
Yes, there are several planets in our solar system that have multiple moons, such as Jupiter, Saturn, Uranus, and Neptune. Jupiter has the most moons, with a total of 79 known moons as of 2021.
Could multiple moons exist in the Earth-Moon system in the future?
It is possible, but highly unlikely, for multiple moons to exist in the Earth-Moon system in the future. The current moon is in a stable orbit, and it would be challenging for any additional moons to enter and remain in a stable orbit without causing significant disruptions. However, it is not entirely impossible, and further research and advancements in technology may provide more insights into the possibility of multiple moons in the future.
10K
