Possibility that all current interpretations of QM are wrong
In summary, there is a possibility that all current interpretations of quantum mechanics are incorrect. Recent studies have revealed discrepancies between theoretical predictions and experimental observations, leading to the questioning of established theories such as the Copenhagen interpretation. Alternative interpretations, such as Many Worlds and Pilot Wave, have emerged, challenging the fundamental principles of quantum mechanics. However, further research and experimentation are needed to fully understand the true nature of quantum mechanics and its implications for our understanding of the universe.
joegibs
47
Is there a possibility that none of the current interpretations of QM are right?
Or is the current interpretations all that there will be on the table?
Of course.
Likes bhobba
It is not even clear if "right" is a meaningful classification.
It is possible that new interpretations will be developed in the future.
Likes physika, WWGD and Orodruin
Do you think that an interpretation as follows could be possible in the future?
The wave function is objectively real (no hidden variables). There is wave function collapse but it doesn't happen instantaneously, it's a physical process that occurs at sublight speed. And it is a local theory. Is this a possible future interpretation?
Quite sure that is ruled out by Bell tests.
Likes ShayanJ
Which part?
joegibs said:
Which part?
We have https://arxiv.org/abs/1303.0614 which shows that if collapse of a Bell state is a physical process, it's not one that propagates at sublight speeds. And of course the (too many to list here) observed violations of Bell's inequality show that no theory in which the wave function is objectively real can be local.
Likes msumm21, vanhees71 and mfb
Is it possible that it really does propagate faster than light? Is it possible that relativity is incomplete?
Would be surprising. Everything faster than light in one reference frame is backwards in time in other reference frames. There is no indication that any reference frame would be special, and violating causality unnecessary would be odd as well.
Likes WWGD and bhobba
Retrocausal interpretations would meet these criteria. Such models are consistent with Special Relativity and restore locality to nonrelativisitc quantum mechanics. They also restore time-symmetry to microphysics. See:
A live alternative to quantum spooks
https://arxiv.org/pdf/1510.06712.pdf
Likes phyzguy
MWI suffers from similar flaws when combined with SR
https://www.physicsforums.com/threads/mwi-and-special-relativity.412608/
The type of FTL phenomena that accounts for the correlations in distant measurements (no matter/energy or information transfer) doesn't appear to be in conflict with relativity.
Certain minimalistic interpretations (Ballentine's ensemble interpretation, Original Copenhagen etc) don't claim anything more than the axioms of quantum mechanics themselves do, so they'll never be "wrong" unless quantum mechanics itself is wrong.
First, by definition all interpretations make the same predictions. If they make different predictions, they are different theories.
A consequence of that is that there is no scientific way to say which is right and which is wrong. To take an example from E&M, is the method of images a right or wrong interpretation?
Next, it looks a lot like the OP is proposing personal theories. We don't discuss them on PF.
mfb said:
It is different. For MWI you don't have to agree when worlds split, different observers can have different conclusions without issue. If you assume a physical collapse process, you have to define when it happens.
But if you assume some type of cloning of worlds while branching, it still sounds confusing. So you would say that there are absolutely no issues when combining MWI and SR?
I don't see where. MWI is local, all the experiments don't depend on what is happening at spacelike separation. If you look at coincidence counts later it does matter, but comparing those results happens at lightlike or timelike distances. Every observer can assume that branching happens according to their reference frame, because there is no need to agree on a time-ordering of the processes.
If wave function collapse is an actual and observer-independent process, then it has to have some time-ordering.
Established that in my opinion, to quote Feynman, no one understands quantum mechanics, I believe that among the "different interpretations", the Copenhagen interpretation "Orthodox" is the most consistent. Although it has elements of ambiguity, the Copenhagen interpretation seems to me the most coherent and more representative of the experimental data. Furthermore it is the most "practical", in order use of the calculations. For example, in the interpretation MW, where are the "other worlds"? There are experimental evidence for the existence of them? It is more simple, in terms of the calculations, thinking that the function of wave collapses, rather, that continue in another space, or the world or universe that is. I'm not saying that the MWI is "wrong." But a quantum physicist, has some practical benefit to use for practical purposes (ie calculation) this interpretation?
One has to specify what's meant by "Copenhagen interpretation". There are plenty of flavors. I can only accept Copenhagen flavors which do not assume an instantaneous collapse. The only interpretation that's consistent for me is the minimal statistical interpretation (also known as "ensemble interpretation"). It just takes the formalism, including the Born rule, i.e., it gives the usual probabilistic meaning to the quantum state, and that's how experiments are indeed done, i.e., one prepares a lot of equally prepared quantum systems (ensembles) and analyses the outcome of measurements statistically.
All scientific theories have a possibility of being wrong.
Likes vanhees71
If you judge theories by their utility, then no single theory is best in all respects. You could say they are all wrong, if what you are looking for is the "final" and "correct" theory of something. The best we can hope for is a "better" theory for some specified scope of behavior.
all in all, you could say, reversing the original question of the thread, that all interpretations of QM are right...
Are interpretations even useful for anything other than theorizing about GUT? Whether you believe that pilot waves are pushing particles around, or if the particle takes all paths at once and collapses, does it matter in the slightest if the math describes what we see?
It's not clear that they're useful even for that purpose.
Likes DrChinese
I don't think they are useful for that.
IMHO their usefulness is in elucidating exactly what the formalism does or does not imply.
Thanks
Bill
Likes Zafa Pi
So if you look at Price, he says in Q2 that in MWI the wave function is objectively real, and in Q12 that MWI is local.
Blaylock also says the same, but goes on to say that MWI is nonCFD.
What do you make of this?
This construction would fit into the general scheme of an Einstein-local realistic theory as used in Bell's theorem, thus, would forbid violations of the Bell inequalities. Thus, it would not be a QM interpretation.
Likes vanhees71
and it would be "wrong" given the empirical facts about the violation of Bell's inequalities and the "accurateness" of the quantum predictions ;-).
Likes Elias1960
I personally make out of this that MWI is pseudoscience. Nothing in this interpretation is well-defined, it makes not even sense to talk about probabilities, but they nonetheless "prove" that their "probabilities" follow the Born rule, and, as usual in inconsistent theories, one can derive everything. Sorry, I could not resist.
Likes Demystifier
MWI is the interpretation you necessarily get if you take the equations of quantum mechanics and don't add any magic. It is the most well-defined interpretation.
Likes Motore
  • #31
It's the most well defined intrinsically, as an interpretation of the Schrodinger equation itself. But when it comes to extrinsic interpretation, namely to interpretation of the experimental observations in terms of those equations, MWI has serious problems.
Likes vanhees71
  • #32
You also have to take the wavefunction as representing a real wave and you have a lack of clarity with the Born rule. This can be sorted out, but MWI after sorting out the Born rule has very similar ambiguities to other interpretations.
Likes vanhees71 and Demystifier
  • #33
I see that differently, but this has been discussed a lot already and I don't want to start yet another iteration of that discussion.
  • #34
If at some point you want to discuss it, it would be interesting to hear as even most MWI authors don't see it that way. They see getting experimental observations out as requiring a lot of additional structure with the details unresolved.
  • #35
I disagree. You have to add a lot of magic. And the equations of quantum mechanics are simply ignored.
From the Schroedinger equation follows, last but not least, a continuity equation for ##\rho(q)=|\psi(q)|^2##. According to MWI, this is a continuity equation for something which does not exist.
12K
