Possible # alleles at locus of 3 base-pairs (diploid)?
In summary, a locus is a spot on a chromosome where a gene is located. There are 64 possible alleles at a locus, each consisting of four possible base-pairs.
Lo.Lee.Ta.
217
How many possible alleles are at a locus consisting of 3 base-pairs in a diploid?
ugh, I am so confused...
So, I guess a locus is just a spot for a gene, so the gene is also considered to consist of 3 bases.
Gene: _ _ _
Each "_" could be either an A,T,C, or G.
So there are 4 possibilities per "_"
So, there are 4 x 4 x 4 = 64 different possible alleles of a gene on one chromosome...?
Since there are 2 chromosomes in a diploid organism, there are 64 x 2 = 128 different possible alleles at a locus...? :(
ugh, I am sure I am WAY off...
Please help me, somebody! )':
Hi Lo.Lee.Ta:
I am not an expert, but I think I can offer some help you can use to search for more information.
The usage of "locus" I know is, with respect to the start of a chromosome, the sequence number of (1) a single base or (2) a triplet. There may be other definitions that I don't know. For your example, I think it refers to (2) the triplet.
The usage of "allele" that I know refers to (1) the particular sequence of bases in a (a) triplet or (b) gene, or (2) (a) to what the triplet codes for (amino acid, start, stop, etc.) or (b) the effect (phenotype) of the whole gene as it might change with different bases. That is, if two different triplets are codes for the same thing, the second usage would call them the same allele. There may be other definitions that I don't know. I am guessing that for your example, the first meaning (1a) is the one you want to use.
My guess is that your calculation of 64 is correct. Counting the possibilities on both strands doesn't make sense because all of those bases in the second strand are constrained by what is in the first strand.
Hope this helps.
Regards,
Buzz
Just thinking aloud, it seemed to me there can only be as many different alleles at a locus as there are amino acids i.e. 20.
Then I thought maybe we should say 21, since a stop triplet replacing an amino acid codon gives mutation.
I even thought: they say triplet not codon - so perhaps there could be two adjacent codons in which you could ring changes - a more complicated calculation.
But then I thought after all we should say 2 - the triplet is either functional or it isn't (first approximation) - and when you talk of alleles you're mostly talking at genetic phenotypic level.
I think if this is a quiz type question I think this last is what I would say. If instead it is a reasoning question, well you decide and write your reasons.
Slight trap question in my opinion.
Hi epenguin:
My interpretation is that no trap was intended. The use of ambiguous terms is the difficulty, and that was probably due to carelessness.
Using allele in the (1a) sense makes the count 64. Using allele in the (2a) sense makes the count 21.
Regards,
Buzz
An allele is simply a generic variant, and the definition does not specify that the variation must have any phenotypic effect. In fact, applications such as DNA fingerprinting purposefully look at alleles that have no known functional consequences (many of these alleles are at non-coding loci, so it would not make sense to think about the amino acid sequence encoded by the allele).
Ah yes I'll go along with that. Not always but a lot of the time you'll be talking about only two, but those two could be any of 64.
I had some suspicions and looked it up. Apparently the word, not that old, comes from a shortening of 'allelomorph' = 'other form'. No doubt the word has a root in common with 'alternative'. I think it really does carry background psychological or historical load of 'one or the other of two'. So the common usage may have involved and expanded a bit. Looking it up in dictionaries and other sources you do often see them mention two forms with 'or more' as rather an afterthought. So you are right but I was not too wrong! :oldbiggrin:
Related to Possible # alleles at locus of 3 base-pairs (diploid)?
What is the meaning of "Possible # alleles at locus of 3 base-pairs (diploid)?"
This refers to the number of different versions of a specific gene that can be found at a particular location on a chromosome, specifically in a diploid organism which has two sets of chromosomes.
How is the number of possible alleles at a locus determined?
The number of possible alleles at a locus is determined by the number of base pairs in the gene sequence. In this case, there are 3 base pairs which can potentially have different combinations, resulting in a certain number of alleles.
What factors can affect the number of possible alleles at a locus?
The number of possible alleles at a locus can be affected by various factors such as genetic mutations, genetic recombination, and genetic drift. These can result in changes to the gene sequence, leading to different combinations of base pairs and therefore, a different number of possible alleles.
Why is it important to know the number of possible alleles at a locus?
Knowing the number of possible alleles at a locus is important for understanding genetic diversity within a population. It can also help in predicting the likelihood of certain traits or diseases being inherited.
How does the number of possible alleles at a locus relate to genetic variation?
The number of possible alleles at a locus is directly related to genetic variation. A higher number of possible alleles indicates a greater potential for genetic diversity within a population, while a lower number of possible alleles suggests a more limited range of genetic variation.
  • Biology and Medical
