Possible Error in Chloric Acid's Lewis Structure
In summary, the conversation discusses the Lewis diagram for chloric acid on Wikipedia and questions whether it is correct due to the apparent violation of the octet rule. It is explained that elements in the 3rd row of the periodic table can expand their valence shell, allowing for more than 8 valence electrons. The concept of hypervalent compounds is also mentioned, with the example of chloric acid being one. It is noted that hypervalent compounds are not very common and chloric acid tends to decompose under certain conditions.
vertciel
63
Hello everyone:
I was looking at Wikipedia's page on chloric acid (http://en.wikipedia.org/wiki/Chloric_acid) and was wondering if the Lewis diagram there is correct. I will not link directly to it as it has a high resolution.
It shows Cl with a lone pair of electrons having double bonds with two O atoms and then a single bond to O - H. Wouldn't Cl have 11 electrons in this case, beyond its limit of 8?
Thanks.
Chlorine would have 12 electrons in its valence shell (10 bonding electrons + 2 in the lone pair) and would indeed seem to violate the octet rule. However, elements in the 3rd row of the periodic table are able to expand their valence shell by involving the 3d orbitals. Other examples of molecules where this occurs are H2SO4 and H3PO4. Elements in the 2nd row cannot expand their valence shells beyond 8 electrons because there are no 2d orbitals.
Thanks for your reply, ygggdrasil.
Does this exception occur often? If so, what would be the maximum number of valence electrons allowed for chlorine? 20?
vertciel - you may be interested in looking up the topic of hypervalent compounds, of which chloric acid is one. I wouldn't really think of them as all that common, but they do pop up frequently enough that one should be aware of them.
The Wikipedia page notes that chloric acid tends to decompose when not kept under certain conditions (under a certain concentration and cold). It's not something which you keep around on a lab bench. Some hypervalent compounds (particularly those of sulfur and phosphorus) tend to be more stable under ambient conditions, though.
FAQ: Possible Error in Chloric Acid's Lewis Structure
What is a Lewis structure?
A Lewis structure is a visual representation of the bonding and electron distribution in a molecule. It shows the arrangement of atoms, lone pairs, and bonding pairs of electrons.
What is the possible error in chloric acid's Lewis structure?
The possible error in chloric acid's Lewis structure is the incorrect placement of lone pairs on the central atom. Chloric acid (HClO3) has a trigonal pyramidal molecular geometry, which means that the central chlorine atom should have one lone pair of electrons. However, some Lewis structures may incorrectly show the central chlorine atom with no lone pairs.
What are the consequences of an error in a Lewis structure?
An error in a Lewis structure can result in an inaccurate representation of the molecule's electronic structure and bonding. This can lead to incorrect predictions of the molecule's properties, such as polarity, reactivity, and shape.
How can an error in a Lewis structure be identified?
An error in a Lewis structure can be identified by checking for violations of the octet rule, incorrect placement of lone pairs, and incorrect number of valence electrons. Additionally, comparing the Lewis structure to the actual molecular geometry and properties of the molecule can help identify any errors.
How can an error in a Lewis structure be corrected?
To correct an error in a Lewis structure, the arrangement of atoms and the distribution of electrons must be adjusted to follow the octet rule and reflect the correct molecular geometry. This can be done by moving lone pairs or changing the placement of double or triple bonds. It is important to remember that all atoms must have a full octet of electrons, and the overall charge of the molecule must be accounted for.
11K
