Possible illogicalness of a 3-sphere shape of the Universe's space?
In summary, the conversation discusses the use of metaphors to depict the universe as a 2-sphere or a 3-sphere. It also considers mapping the three dimensions of space onto the "surface" of a 3-sphere and the differences between positional symmetry in these models. The possibility of using different coordinate systems and the challenges it may bring is also discussed. Ultimately, it is concluded that while the geometry of a 3-sphere is different from Euclidean 3-space, certain coordinate systems, such as 3-dimensional spherical coordinates, can be used to work with this type of space.
greswd
764
Metaphorical depictions of the universe in the shape of a 2-sphere are very common.
Now, let's consider mapping the three dimensions of space onto the "surface" of a 3-sphere. Like Non-Euclidean de Sitter geometry.
The surface of a sphere is positionally symmetrical. However, the positional symmetry of the surface being mapped to is distinct from the positional symmetry of the space being mapped.
We could represent the space in terms of a co-ordinate system, and likewise for its positional symmetry.A Cartesian co-ordinate system has a high degree of positional symmetry, so we consider a three-dimensional Cartesian grid, equivalent to a honeycomb of cubes. Each cube being surrounded by and making contact with 26 cubes.
I think a problem arises when we consider all the Platonic polyhedroids/polychorons. There's only one made with cubes, the tesseract.
Because there doesn't appear to be a magical number of cubes which space can be divided into. And so, if the three dimensions of space can be mapped to a 3-sphere, I daresay we might expect there to be an infinite number of cubic Platonic polyhedroids.And a tesseract has a different configuration as well, each of its cubes only makes contact with 6 cubes, not 26.
For the cubic honeycomb, each edge is shared by 4 cubes, and each vertex by 8 cubes, yielding for 8 cubes, 24 edges and 8 vertices.
A tesseract, on the other hand, has 32 edges and 16 vertices.Now you might be confused by the mentions of "non-Euclidean" and "Cartesian", however, I've already mentioned a distinction between the two positional symmetries.
Also, there's still only one cubic Platonic polyhedroid.All of this appears to imply to me that it is illogical to map the three dimensions of space onto a 3-sphere.
  • Skeptical
Likes PeroK
Space news on Phys.org
That is not what is being done in models of the universe in which it is spatially a 3-sphere. What you are calling "space" is actually just one particular 3-dimensional spatial geometry, called "Euclidean 3-space". It is not the only possible 3-dimensional spatial geometry.
No, what it shows (to the extent it shows anything--some of what you say is just confused) is that the geometry of a 3-sphere is different from the geometry of Euclidean 3-space. Mathematicians have known this for getting on for two centuries now.
This is not the geometry of a 3-sphere. It's the geometry of a particular 4-dimensional spacetime, not a spatial geometry at all.
So I'd like to know, is it possible to map a cubic honeycomb, each and every cube being surrounded by 26 cubes, to a 3-sphere?
Assuming that that is relevant to 3-sphere models of the universe.
greswd said:
is it possible to map a cubic honeycomb, each cube being surrounded by 26 cubes, to a 3-sphere?
To a small portion of a 3-sphere, yes. A small portion of a 3-sphere works the same as a small portion of Euclidean 3-space. The differences are global, not local. For one thing, the total volume of a 3-sphere is finite, but the total volume of Euclidean 3-space is infinite.
I edited my reply to say "each and every cube", though I guess you replied earlier in that brief window.
So since its not "each and every", I'm puzzled and still have question(s), sorry; how do 3-sphere models apply a global, positionally symmetrical co-ordinate system to three-dimensional space?
I already answered that version of the question anyway. Read the last sentence of post #5.
They don't. As I've already said, Euclidean 3-space (which is what you are misleadingly referring to as "three-dimensional space", as if it were the only such space, which it isn't) is a different geometry than a 3-sphere, just as the Euclidean 2-plane is a different geometry than a 2-sphere. So obviously you can't use the same global coordinates for both.
I was not specifying Euclidean 3-space in #6, but nevermind, to ensure clarity, although non-Euclidean, cosmologists still have to work with some kind of 3-space, three dimensions of space, three different numbers.
and I was also asking about different co-ordinate systems.
what sort of global, positionally symmetrical co-ordinate system do 3-sphere theorists apply to the kind of space they work with?
3-dimensional spherical coordinates are the most common ones.
hmm, though it isn't really positionally symmetric, requiring a central radial position
and it can be readily converted to Cartesian co-ordinates, and therefore might lead back to the original problem
The coordinate origin is an artifact of the choice of coordinates. You could equally well choose any point you like to be the origin; they're all the same as far as the actual geometry is concerned, just as all points on a 2-sphere are the same as far as the geometry is concerned, even though if we put 2-spherical coordinates on them we have to pick one such point to be the origin.
No, it can't. We're not talking about spherical coordinates on Euclidean 3-space. We're talking about spherical coordinates on a 3-sphere. The transformation you show is only valid between spherical and Cartesian coordinates in Euclidean 3-space. It is not valid on a 3-sphere.
It is possible to have coordinates on a 3-sphere that are like Cartesian coordinates in a small patch of the 3-sphere, but they can't be extended globally, just as it's possible to have coordinates on a 2-sphere that are like Cartesian coordinates in a small patch of the 2-sphere, but they can't be extended globally.
I strongly suggest that you take some time to think carefully about how things work on a 2-sphere. A 3-sphere is similar, just with one more dimension.
Note that by this I did not actually mean the coordinates ##\rho##, ##\theta##, ##\phi##, although you can use those on a 3-sphere (but they won't work the same as they do in Euclidean 3-space). I meant the 3-sphere analogue of latitude and longitude, i.e., three angular coordinates (instead of the two we use on a 2-sphere).
Am I right in understanding that the rather artistic diagram at the top of the OP is of a sequence of 2-spheres embedded in a 3d space - the universe in this picture is the surface of each sphere, not the body of the enclosed ball? But this is just a diagram, and the real model is the surface of a 3-sphere that would need to be embedded in a 4d space if we wanted to draw it (but I guess the model doesn't include an embedding space). So the problem with the coordinate transform in #10 is that it relates coordinates on the 2-sphere to Cartesian coordinates in the embedding space - which doesn't exist in the model, only the diagram?
If so then the transform needed is between coordinates on a 3-sphere, which presumably has three angular coordinates, and Cartesian coordinates in a 3-space. This will have all the same issues that maps of the world have - they can be reasonably good representations over small regions, but must be distorted over large regions and actually torn if you try to cover the globe. But you can draw an honest flat map of any small region - and that's the relevant symmetry.
we know that each point on the 3-sphere is the same as any other point, a symmetry of each point in 3-D space
Imagine that we can materialize identical solid metal cubes out of thin air. We start materializing cubes and packing them together into a cubic honeycomb, a solid honeycomb ironically.
eventually we will have so many cubes that we will fill up almost all of the volume of the 3-sphere universe, and it will have to terminate. What will the termination of this process look like?
And we can also consider a 3-sphere universe which has a really tiny volume.
Depends on what process you use to force things as the mismatch between your cube and the underlying geometry grows, I would imagine. Your fundamental problem is that a Cartesian approach doesn't reflect the symmetry of a spherical space - so your statement in the OP that a "Cartesian co-ordinate system has a high degree of positional symmetry" is where you went wrong. It has translational symmetry in a flat space, but you are not operating in a flat space.
yeah, so I'm wondering how it works out logically
what sort of mismatch would we start to observe?
because i was thinking about the positional symmetry, every point in space being identical to any other point.
You have global rotational symmetries instead of translational ones.
Your cubes would need to be squashed at their outside edges because the circumference of a circle of radius ##r## is less than ##2\pi r## in this space.
It is. You can start piling up cubes at any point and you'll get the same failure mode. Contrast, for example, a black hole spacetime where you can pile cubes happily for a long time if you start distant from the hole, but will rapidly run into problems if you start near the hole.
Squashed because the leftmost side of our honeycomb pile bumps into the rightmost side?
Before that. Imagine tiling the surface of the Earth. Build a complete single row of tiles around the equator. Fine. Now try to add another row, touching it on the north edge. You can't do it, because the line of constant latitude at the north edge of the new row is shorter than the one at the south edge - there isn't room for square tiles. The problem gets worse as you get further away from the first ring, but it's present right there.
Now let's go back and look at just that first equatorial ring. The problem actually applies even to this - the corners of each tile must be slightly lifted off the surface if the middle touches. The underlying reason for this is that you cannot build a Euclidean square on the surface of a sphere because it isn't a Euclidean surface. Thus your Cartesian grid fails right from the word "go", because it doesn't reflect the symmetries of the space in which you are attempting to define it.
@Ibix @PeterDonis
Per Ibix's suggestion, I'm considering the POV of a flatlander on (or in) the surface of a 2-sphere.
A flatlander has no conception of the 3rd dimension of space, so to him the 2-sphere is a flat plane in which he can move about infinitely in any direction, though he might end up looping around back to where he started.
I start with a cube, its a Platonic solid and topologically similar to a 2-sphere. The cube has to be squished onto a flat plane.
Say said cube is a dice, and our flatlander is located on the 1-dot face.
After drawing 5 faces, its unclear how we ought to proceed further.
The 6-dot face is a convex quadrilateral, but it is also connected to all of the four outer quadrilaterals.
Though this resembles the Schlegel diagram of the cube.We can repeat it with polyhedra which have more faces and are rounder in shape, like the truncated icosahedron.
Once we've reached the stage of the right image, its also unclear how to proceed further, and it also resembles the Schlegel diagram of the truncated icosahedron.
How do you think we could proceed further?
No it isn't. He can make measurements on a relatively small scale to show that the space is non-Euclidean. Triangle angles don't quite add to 180, for example, and the larger you make the triangle the worse the difference becomes.
This is different from a cube, which is mostly flat with some very curved regions at the corners.
yeah, but he observes all this within two dimensions of space, he can't visualize the curvature in the third dimension
so what do you think of the "Schlegel diagrams"?
Note, however, that the issue with a black hole spacetime is different from the issue with a 3-sphere. In a black hole spacetime, you can fit more cubes radially than you would expect based on tangential distances, whereas in a 3-sphere you can fit fewer.
And that's why we apply non-Euclidean geometry - to provide a mathematical description of something we cannot visualise. The same tools are available to a Flatlander. Or Curvedlander, I suppose.
I don't see what you are trying to achieve. Why not just use a Mercator projection, or stereographic projection, or whatever?
True - @robphy linked these models the other day, which may be relevant.
Though I was trying to express how a flatlander's perception, or "reality", is still very much within a 2-D planar framework.
I'm trying to expand the map of space outwards from our flatlander's location. From his POV, which is limited to two dimensions of space.
For a stereographic projection, locations further away would have their distances stretched greatly, until the opposite pole is at infinity, which does not conform to the actual distance.
And as our flatlander can also perceive that he is moving in one direction only in a straight line while he is actually looping around, the map of space could go on infinitely, but with repetitions.
Wait - do you have that the right way round? On a sphere you should see more cubes radially than naive analysis of the circumference would suggest, surely?
You can't draw a sphere on a plane without stretching or tearing it. It's not possible. You could certainly rescale a stereographic projection so that the pole is at finite distance, but each circle of constant latitude must be larger than its predecessor, which isn't the case on the sphere.
so from #20, I think the map of space should continue outwards indefinitely, but as mentioned, unclear how to proceed after inadvertently reproducing Schlegel diagrams.
  • #31
Yes, you're right, I misstated the difference between the black hole spacetime (more precisely, a single spacelike slice of constant Schwarzschild coordinate time in a black hole spacetime) and a 3-sphere. Giving the math will make it clearer: the 3-sphere metric, in "Schwarzschild-like" coordinates where ##r## is the areal radius and we have picked any point we like as the origin, is:
ds^2 = \frac{1}{1 - k r^2} dr^2 + r^2 d\Omega^2
where ##k## is a constant related to the "Radius of curvature" of the 3-sphere.
The metric of the Flamm paraboloid, which is the geometry of a constant Schwarzschild time spacelike slice of a black hole spacetime, is:
ds^2 = \frac{1}{1 - \frac{2M}{r}} dr^2 + r^2 d\Omega^2
where ##M## is the mass of the hole.
Both of these metrics have the coefficient of ##dr^2## larger than 1, so you are right that they both allow you to fit more cubes radially than you would expect based on tangential distances. But the dependence on ##r## of how many more cubes you can fit radially is very different.
Likes Ibix
  • #32
Obviously it can't, since the area of a 2-sphere is finite. Similarly, it is impossible to continue any "cube" construction outward indefinitely in a 3-sphere space, since the volume of the space is finite.
  • #33
yup, a finite play space, though in #20 I mentioned infinite looping:
and in #27 to Ibix repetitions
with the infinite map representing repeated loops
  • #34
As long as you allow multiple squares or cubes to occupy the same space, which I suppose is OK if they're just abstract, but doesn't work if they are actual objects.
  • #35
I was thinking in terms of something similar to Pac-Man on a torus.
The infinite map would look like this:
And the infinite map includes Pac-Man himself repeated infinitely, as its like the 2007 physicsy video game Portal in which you can look at your own back:
There's also a video, though it shows the environment moving around the torus instead of Pac-Man
<h2>1. What is a 3-sphere shape and how does it relate to the Universe's space?</h2><p>A 3-sphere shape is a mathematical concept that describes a three-dimensional sphere with a constant positive curvature. It is often used to model the shape of the Universe's space, as it suggests a closed and finite space with no boundaries.</p><h2>2. Is there evidence for a 3-sphere shape of the Universe's space?</h2><p>Currently, there is no conclusive evidence for a 3-sphere shape of the Universe's space. The shape of the Universe is still a subject of ongoing research and debate among scientists. Some theories and observations suggest a flat or open Universe, while others propose a closed and finite Universe.</p><h2>3. How does a 3-sphere shape of the Universe's space affect our understanding of the Universe's expansion?</h2><p>If the Universe's space is indeed a 3-sphere, it would have important implications for our understanding of the Universe's expansion. A 3-sphere shape would suggest that the Universe is finite and has a finite volume, which could potentially affect the rate and direction of its expansion.</p><h2>4. Are there any alternative theories to the 3-sphere shape of the Universe's space?</h2><p>Yes, there are several alternative theories to the 3-sphere shape of the Universe's space. Some propose a flat or open Universe, while others suggest a more complex and multi-dimensional structure. These theories are still being studied and evaluated by scientists.</p><h2>5. What are the potential implications of the 3-sphere shape of the Universe's space for our understanding of the laws of physics?</h2><p>If the Universe's space is a 3-sphere, it would have significant implications for our understanding of the laws of physics. It could potentially challenge some of our current theories and require us to revise or expand our understanding of the fundamental principles that govern the Universe.</p>
Related to Possible illogicalness of a 3-sphere shape of the Universe's space?
  • Cosmology
  • Quantum Physics
  • Differential Geometry
  • Science Fiction and Fantasy Media
  • Topology and Analysis
