I Possible to derive geodesics from the wavefunction?
Gotbread
TL;DR Summary
Does time dilation applied to the wave function lead to acceleration?
Background
While watching Does time cause gravity? from PBS Spacetime, i wondered if its possible to "derive" the geodesic equation
not from GR alone, but by assuming each particle is described by an extended wave function and the time evolution
of this wave is not constant but the rate varies depending on position, based on the time dilation.
Mathematical attempt
We start with the time dependent schrödinger equation for a free particle:
$$i\hbar\frac{\partial}{\partial t} \Psi(x, t) = \frac{-\hbar^2}{2m} \frac{\partial^2}{\partial x^2} \Psi(x, t)$$
Now we add a dilation factor in. As a simple approximation we assume a constant acceleration field
which would result in a linear dilation factor:
$$D(x) = \frac{1}{1+kx\epsilon }$$
Where ##k## is a vector pointing along the acceleration field and ##\epsilon ## is the linearized factor
which describes the strength of the field. The result ##D(x)## describes the relative clock rate
of something at the position ##x## as seen from the perspective of someone sitting at ##x=0##.
If you are "higher up" in the field you would have a higher clock rate ##(>1)## as seen by our observer,
if you are "lower" you would have a lower clock rate ##(<1)## as seen by the observer.
For a more accurate model one would have to derive the position dependent clock rate from e.g. the schwarzschild
metric, but as a linear approximation for small scales (size of a particle) it should be good enough. Since on
e.g. Earth the time dilation effect is very small, ##\epsilon## will be very small as well.
Now we modify our original equation to include the dilation rate:
$$i\hbar\frac{\partial}{\partial t} \Psi(x, t) = D(x)\frac{-\hbar^2}{2m} \frac{\partial^2}{\partial x^2} \Psi(x, t)$$
Now we plug in the initial state of a single particle at rest and see what happens. Of course it will initially
spread out, but will it pick up momentum?
And if so, is this acceleration experienced consistent with the same acceleration we would get from "normal"
gravity?
Gotbread said:
Summary:: Does time dilation applied to the wave function lead to acceleration?
No. PBS Spacetime is fun, but it’s not a real textbook and it oversimplifies so much that it can’t be used as a basis for developing a deeper understanding or new concepts. If you want to explore the relationship between relativity and quantum mechanics you’ll need a textbook on quantum field theory. Srednicki is one of the few that is available online. Lancaster and Blundell “Quantum field theory for the gifted amateur” isn’t free but is an easier read; anything that simplifies beyond that probably isn’t worth reading,
Please do respect the forum rule about not allowing personal theories and speculation.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
