Potassium alum: how to prevent recrystallization in water?
  • Thread starter Thread starter Antonspb
To prevent the recrystallization of potassium alum in aqueous solutions upon cooling, it is recommended to use less alum when preparing the solution. Maintaining the solution in contact with the solid at the experimental temperature can also help. If the solution becomes oversaturated as it cools, crystallization is inevitable, and there are no reliable methods to prevent this process entirely. The analogy used highlights that once the support is removed, the solid will fall, emphasizing the challenge of preventing crystallization once conditions favor it.
Antonspb
TL;DR Summary
Potassium alum forms crystals after cooling down of its water solution.
How do I prevent it from recrystallizing?
Dear all,
I am trying to find out how to prevent the recrystallization of potassium alum in aquaeous solution when it cools down. It dissolves in water when heated, but forms crystals when no longer hot.
Do you have any tips or ideas on how to keep it from recrystallization in water solution?
I need it so the crystals stop clogging small-diameter tubes
Thanks for your ideas and best regards,
Anton
Chemistry news on Phys.org
Use less alum when preparing the solution (better yet: use solution that is in contact with the solid at the experiment temperature). If the solution becomes oversaturated on cooling solid will drop out, there are no reliable tricks that can prevent it.
More or less you are asking "what to do to keep stone in the air and stop it from falling when I remove the support" :wink:
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
