Potenial inside Wedge due to Line Charge
In summary, the problem involves a wedge configuration with two conducting planes at zero potential, connected by a conducting cylinder and with an infinite line charge held a distance away. Using separation of variables and boundary conditions, an expression for the potential in the region between the conducting plates can be obtained. This expression involves a sum of terms containing a constant ##A_m##, which can be found by enforcing the boundary condition at ##r=d##.
CopyOfA
35
We are given a wedge configuration with three sections. There are two conducting planes held at zero potential that make an angle of ##2\beta## with each other. They are connected by a portion of a conducting cylinder with radius ##a##. An infinite uniform line charge of ##\rho_l## is held at a distance of ##d## away from the center of the conducting cylinder. Use separation of variables to find an expression for the potential in the area between the conducting plates.
In the space between the plates, excluding the line charge, ##\nabla^2 \phi\left(r,\theta\right) = 0##. In cylindrical coordinates, the solution to Laplace's equation is:
\begin{align*}
\phi\left(r,\theta\right) &= \sum_{\alpha}R_{\alpha}\left(r\right)G_{\alpha}\left(\theta\right)
\end{align*}
given that ##\theta## is the angle measured from line connecting ##r=0## and ##r=d##. The full differential equation for this problem can be expressed as:
\begin{align*}
\left(\dfrac{\partial^2 }{\partial r^2} + \dfrac{1}{r}\dfrac{\partial }{\partial r} + \dfrac{1}{r^2}\dfrac{\partial^2 }{\partial \theta^2}\right)\phi\left(r,\theta\right) = -\dfrac{\rho_l}{\epsilon_0 r}\delta\left(r-d\right)\delta\left(\theta\right)
\end{align*}
The boundary conditions are:
\begin{align*}
&\phi\left(r,\theta = \frac{\pi}{2}-\beta\right) = 0\\
&\phi\left(r,\theta = \frac{\pi}{2} + \beta\right) = 0\\
&\phi\left(a, \frac{\pi}{2}-\beta <\theta < \frac{\pi}{2} + \beta\right) = 0
\end{align*}
In order to satisfy the boundary condition at ##\theta = \frac{\pi}{2}-\beta## and ##\theta = \frac{\pi}{2}+\beta##,
\begin{align*}
G_{\alpha}\left(\theta\right) = \cos\left(\alpha_m \theta\right) = \cos\left(\dfrac{m\pi}{2\beta}\theta\right), \mbox{ for } m=1,3,5,...
\end{align*}
This function is zero at the locations of the grounded plates. Hence,
Carrying out the derivative,
\begin{align*}
&=\cos\left(\alpha_m \theta\right)\dfrac{d^2 R}{dr^2} + \cos\left(\alpha_m \theta\right)\dfrac{1}{r}\dfrac{dR}{dr} + \dfrac{R}{r^2}\left(-\alpha_m^2 \cos\left(\alpha_m \theta\right)\right) \\
&= -\dfrac{\rho_l}{\epsilon_0 r}\delta\left(r-d\right)\delta\left(\theta\right)
\end{align*}
Along the line connecting ##a## and ##d##, ##\theta = 0##
\begin{align*}
\dfrac{d^2 R}{dr^2} + \dfrac{1}{r}\dfrac{dR}{dr} - \dfrac{\alpha_m^2}{r^2} = -\dfrac{\rho_l}{\epsilon_0 r}\delta\left(r-d\right)
\end{align*}
Hence, for ##\alpha_m=0##,
\begin{align*}
R\left(r\right) = \begin{cases}
A\ln\left(r\right) + B, & r<d\\
C\ln\left(r\right) + D, & r>d
\end{cases}
\end{align*}
It's clear that the first of these equations is:
\begin{align*}
R\left(r\right) = -\dfrac{\rho_l}{2\pi\epsilon_0}\ln\left(\dfrac{r}{a}\right)
\end{align*}
For ##\alpha_m^2 \neq 0##,
\begin{align*}
R\left(r\right) = A_m\left[\left(\dfrac{r}{a}\right)^{\alpha_m} - \left(\dfrac{a}{r}\right)^{\alpha_m}\right]
\end{align*}
This function satisfies Laplace's equation and is equal to 0 at ##r=a##.
My question is: how can I find ##A_m##? I have no other boundary conditions to satisfy...
To find the value of ##A_m##, you can use the boundary condition at ##r=d##, which is given by:
\begin{align*}
\phi\left(d,\theta\right) = \sum_{m=0}^{\infty}A_m\left[\left(\dfrac{d}{a}\right)^{\alpha_m} - \left(\dfrac{a}{d}\right)^{\alpha_m}\right]\cos\left(\dfrac{m\pi}{2\beta}\theta\right)
\end{align*}
Substituting in the value of ##G_{\alpha}\left(\theta\right)## and using the fact that ##\phi\left(d,\theta\right) = 0##, you can solve for ##A_m##. This will give you the complete expression for the potential in the region between the conducting plates.
Related to Potenial inside Wedge due to Line Charge
1. What is a Wedge and Line Charge?
A Wedge is a 3-dimensional geometric shape with a triangular base and sloping sides. A Line Charge is an infinitely long, straight line with a constant charge density.
2. Why is the Potential Inside a Wedge due to Line Charge important?
The Potential Inside a Wedge due to Line Charge is important because it helps us understand the behavior of electric fields and charges in a confined space, which has many practical applications in fields such as physics, engineering, and technology.
3. How is the Potential Inside a Wedge due to Line Charge calculated?
The Potential Inside a Wedge due to Line Charge is calculated using the equation V = (λ/2πε0) * ln(r/(r-πb)), where λ is the charge density of the line, ε0 is the permittivity of free space, r is the distance from the line charge to the point in the wedge, and b is the length of the base of the wedge.
4. What factors affect the Potential Inside a Wedge due to Line Charge?
The Potential Inside a Wedge due to Line Charge is affected by the charge density of the line, the distance from the line to the point in the wedge, and the length of the base of the wedge. Additionally, the angle of the wedge and the orientation of the line charge can also affect the potential.
5. Can the Potential Inside a Wedge due to Line Charge be negative?
Yes, the Potential Inside a Wedge due to Line Charge can be negative. This occurs when the distance from the line to the point in the wedge is smaller than the length of the base, resulting in a negative natural logarithm value in the calculation. This negative potential indicates that the point is at a lower energy level compared to a point at infinity.
