Potential at the corner of a insulated charged cube
In summary, we are given an insulating cube with a uniform charge density and a potential of zero at a infinite distance from the cube. The potential at the center of the cube is Vo and we need to find the potential at a corner of the cube. By considering the potential at the center of a charged cube with twice the length, we can use the principle of superposition and dimensional analysis to determine that the potential at a corner of the cube will be 8 times the potential at the center of the smaller cube. Using Mathematica, it has been calculated that when the length of the cube is doubled, the potential also doubles, which supports the dimensional analysis. Therefore, the potential at the corner of the cube will be 8 times
idon'tknowphy
An insulating cube of edge a has a uniform charge density p. The charge is zero everywhere outside the cube. The potential at an infinite distance from the cube is taken to be zero. If the potential at the center of the cube is Vo, find the potential at a corner of the cube. (Hint: Consider the potential at the center of a charged cube with the same charge density but with twice the length of the edge, use the principle of superposition in combination with a dimensional analysis.)
The problem is, I don't know how to find the potential at the center of a charged cube with length of the edge 2a
i don't know if i am able to use gauss law to find the E-field out side and inside the cube
i know that i can make a cube of side 2a by putting 4 cubes together, so the potential at the center of cube of side 2a will be
V_center of cube 2a = 8 V_corner
Make 7 copies of the charged cube of length a. We want to know the potential at the corner of the smaller cube, call that Vc. Arrange the 8 cubes into a larger cube of length 2a. We know that the potential at the center of the larger cube will be 8*Vc. We must now relate that to the known potential at the center of the smaller cube which is Vo somehow using dimensional analysis.
I'm stuck for now %^(
i used Mathematica to calculate the potential at the center of the cube,
when a->2a, the potential will be 4 times larger
But i can't see it intuitively!
I'll throw this out and see if it makes sense.
Suppose we have cubes of uniform charge rho and of various size a. Let the potential at the center of such cubes be given by,
V = V(Q,R) where Q is the total charge on the cube and R is the length of the cubes edge.
Dimensionally
V = constant*Q/R
If this is true then if we double the edge length then Q --> 8Q and R --> 2*R so V --> 4V
Am I getting closer?
of cube a
I would approach this problem by first considering the basic principles of electrostatics. The potential at a point is defined as the work done per unit charge to bring a small positive test charge from infinity to that point. In this case, we can use the principle of superposition to find the potential at a corner of the cube by considering the potential due to each of the six faces of the cube individually.
We can start by considering a cube with edge length 2a, as suggested in the hint. The potential at the center of this cube can be calculated using the formula V = kq/r, where q is the total charge of the cube and r is the distance from the center. Since the charge density is uniform, we can use the formula for the total charge of a cube, q = pV, where V is the volume of the cube. In this case, V = (2a)^3 = 8a^3. Therefore, the potential at the center of the cube with edge length 2a is:
V_center of cube 2a = (k*p*8a^3)/(2a) = 4kpa^2
Now, we can use the principle of superposition to find the potential at the corner of the cube with edge length a. This means we need to consider the potential at the corner due to each of the six faces of the cube with edge length 2a. The distance from the corner to the center of each face is a, so we can use the formula V = kq/r, with q = p*a^3 for each face. This gives us a potential of:
V_corner of cube a = 6 (k*p*a^3)/a = 6kpa^2
Therefore, the potential at a corner of the cube is 6 times smaller than the potential at the center of a cube with twice the edge length. This makes sense, as the charge is spread out over a larger volume in the bigger cube, resulting in a smaller potential at a given distance.
In summary, the potential at a corner of the cube is V_corner of cube a = (1/6)V_center of cube 2a = (1/6)*4kpa^2 = (2/3)kpa^2. This solution was found using the principle of superposition and dimensional analysis.
Related to Potential at the corner of a insulated charged cube
What is the potential at the corner of a insulated charged cube?
The potential at the corner of a insulated charged cube is the measure of the electric potential energy per unit charge at that specific point. It is influenced by the distance from the corner to the charged cube and the amount of charge on the cube.
How is the potential at the corner of a insulated charged cube calculated?
The potential at the corner of a insulated charged cube can be calculated using the formula V = kQ/r, where V is the potential, k is the Coulomb's constant, Q is the charge on the cube, and r is the distance from the corner to the cube. It can also be calculated by summing the potential contributions from each face of the cube using the formula V = kQ(1/a + 1/b + 1/c), where a, b, and c are the distances from the corner to each face of the cube.
What is the relationship between the potential at the corner of a insulated charged cube and the distance from the corner?
The potential at the corner of a insulated charged cube is inversely proportional to the distance from the corner. This means that as the distance increases, the potential decreases. It follows the same relationship as the inverse square law for electric fields, where the electric field strength decreases with increasing distance.
Can the potential at the corner of a insulated charged cube be positive, negative, or zero?
The potential at the corner of a insulated charged cube can be positive, negative, or zero depending on the charge of the cube and the distance from the corner. If the cube has a positive charge, the potential at the corner will be positive. If the cube has a negative charge, the potential at the corner will be negative. If the cube is neutral, the potential at the corner will be zero.
How does the potential at the corner of a insulated charged cube affect the electric field at that point?
The potential at the corner of a insulated charged cube is directly related to the electric field at that point. The electric field points in the direction of the decreasing potential, so if the potential at the corner is positive, the electric field will point away from the corner, and if the potential is negative, the electric field will point towards the corner. The stronger the potential, the stronger the electric field at that point.
