A Potential between Photons via Delbruck Scattering
  • A
  • Thread starter Thread starter DuckAmuck
    Scattering
DuckAmuck
TL;DR Summary
Delbruck scattering generates potential between photons.
From the Born Approximation, you can relate the potential to the scattering amplitude. So it follows that a potential can be derived from the scattering amplitude from Delbruck scattering. I tried to solve this myself, and get a scattering amplitude with only angular dependence, no momentum dependence. This seems to imply that the potential and force between two photons would be long-range? This is clearly incorrect. I would appreciate any help.
It's hard to guess, what you did. Of course there's no "potential between photons". Delbrück scattering is described in leading order QED by box diagrams with four external photon lines. It's a pretty cumbersome calculation. See Landau&Lifshitz vol. 4.
Likes topsquark and PeroK
On an unrelated note: Thank you! I didn't know the name for this. All I had heard of was "scattering of light by light."
-Dan
DuckAmuck said:
TL;DR Summary: Delbruck scattering generates potential between photons.
Perhaps worthwhile would be to post some if not all of your calculations. As a PDF would be ok.
First, I agree - we should call this "light by light" and not "Delvruck". It's closer to what you mean.
Next, at leading order, scattering is the same for attraction and repulsion. So the first order where it makes a difference is α6. I suspect that this is calculated somewhere, probably in someone's thesis. Maybe it's published somewhere.
Massless particles don't form bound states, so what is meant by attraction and repulsion needs to be carefully defined. Without doing the calculation (well beyond my abilities) I suspect there is a dependence on the relative phases of the photons.
The leading order are box diagrams with four vertices, i.e., the cross section is of order ##\alpha^4##. It's a genuinely relativistic effect of course, because it involves the massless photons, and thus you cannot expect that this has anything to do with potentials. It's also a pure quantum effect, i.e., due to quantum fluctuations of the quantum fields involved. As I said, you find the calculation in Landau and Lifshitz vol. IV. The calculation is indeed very cumbersome.
What's important to note is that this four-photon diagram is superficially logarithmically divergent. If it were really divergent, it would be a desaster for the renormalizability of QED, because there is no renormalizable counter term for such a divergence. Fortunately, gauge invariance comes to the rescue, and the Ward-Takashi identities tell you before you have done any calculation that indeed the four-photon vertex is finite. This is not true for any single box diagram but for the sum of all the 6 box diagrams.
Likes strangerep and dextercioby
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
