Potential difference and a proton
In summary, a proton with a mass of 1.67x10^-27kg and a charge of 1.6x10^-19C moves from point A to point B under the influence of an electrostatic force only. The proton starts at point A with a speed of 50km/s and ends at point B with a speed of 80km/s. To determine the potential difference between point B and point A, we can use the equation delta V = delta U/q and relate the change in kinetic energy to the potential difference. By solving for delta U and dividing by the charge of the proton, we find that the potential difference is +20V. It is important to include units when working a problem, especially when
cuppy
a proton (mass=1.67x10^-27kg, charge 1.6x10^-19C) moves from point A to point B under the influence of an electrostatic force only. at point A the proton moves with a speed of 50km/s and at point b it moves with a speed on 80km/s. determine the potential difference vb-va.
delta V=delta U/Q
also, in a uniform field delta V=-Ed
F=qE=ma
i don't know if enough information is provided in the question. i tried to find the acceleration of the proton as its speed increased from 50km/s to 80km/s but the question does not say how long it took to happen or how far it traveled in that time so using a=(v-u)/t cannot be found.
Similarly, i can't find a way of obtaining the electric field because all we are given is the charge of the proton and the magnitude of the force is also not specified and can't be foind from f=ma since i can't get a.
am i missing something or overlooking any details in the question? any help would be great
I would say the kinetic energy gained by the proton is the same as the change in potential energy between the two points, which you can relate to the potential difference. Try that.
hey THANKS :approve: i can't believe i didn't see that before!
taking that approach, i used delta V= delta U/q
after finding delta U from delta KE = - delta U
so 1/2mv^2 final - 1/2mv^2 initial equalled 3.2565x10^-18, so change in potential energy was -3.2565x10^-18.
dividing that by the charge of a proton i got +20V.
can anyone tell whether my steps have brought me to the correct answer?
20V is correct, however one should show the units when working a problem, particularly when there are mixed systems (MKS/cgs) involved, which is not the case here.
Kinetic energy in the MKS system has units of kg-m2/s2 = Nt-m = J, and 1 V = 1 J/C, where C = Coulomb.
ok i will definitely keep that in mind for next time.
FAQ: Potential difference and a proton
What is potential difference?
Potential difference, also known as voltage, is the difference in electric potential energy between two points in an electric field. It is measured in volts (V) and represents the amount of work needed to move a unit of charge between those two points.
What is a proton?
A proton is a subatomic particle that has a positive charge and is found in the nucleus of an atom. It has a relative mass of 1 and is represented by the symbol "p" or "+". It is one of the building blocks of matter.
How does potential difference affect a proton?
Potential difference affects a proton by exerting a force on it. The direction of this force depends on the direction of the electric field. If the potential difference is positive, the proton will move towards the lower potential. If the potential difference is negative, the proton will move towards the higher potential.
What is the relationship between potential difference and a proton's kinetic energy?
The relationship between potential difference and a proton's kinetic energy is described by the equation ΔKE = qΔV, where ΔKE is the change in kinetic energy, q is the charge of the proton, and ΔV is the change in potential difference. This means that as potential difference increases, the proton's kinetic energy also increases.
How is potential difference measured?
Potential difference can be measured using a voltmeter, which is a device that measures the electric potential difference between two points in a circuit. It is connected in parallel to the component or circuit being measured and displays the potential difference in volts.
