Potential difference between two plates
In summary, for an α-particle accelerated between a pair of parallel plates in a vacuum tube, the potential difference between the plates is 500 V. This is calculated by dividing the kinetic energy of the particle (103 eV) by the charge of the particle (2e), giving a result of 500 V.
moenste
711
An α-particle accelerated between a pair of parallel plates in a vacuum tube acquires a kinetic energy of 103 eV. What is the potential difference between the plates?
Answer: 500 V
2. The attempt at a solution
Well, it's 1000 / 2 = 500 V because there are two plates. But I am not sure whether this is the right logic.
Also KE = e * V. If we use this, we have (1000 * 1.6 * 10-19) J = 1.6 * 10-19 * V and so V = 1000 V. And not 500 V as in the answer.
Is it correct to just divide 1000 by 2 and get 500 V and that is the answer in this case?
Thanks in advance!
It's wrong, two plates you can seem capacitor and between two plates have electric field
and it provides for paticles a KE. You must find the work is caused by electric field. It equals ##\Delta KE##
Likes moenste
Thank you. Is this what you mean?
W (work) = e * V
KE = e * V
(1000 * 1.6 * 10-19) = 1.6 * 10-19 * V
V = 1000 V
KE = e * V.
It wrong KE=q.V with q is the charge of α
Likes moenste
Hamal_Arietis said:
KE = e * V.
So we have:
KE = 1000 * 1.6 * 10-19 J (or 1000e)
q = 2 * e = 2 * 1.6 * 10-19 C (or 2e)
V = ?
1000 * 1.6 * 10-19 = 2 * 1.6 * 10-19 * V
or
1000e = 2e * V
V = 1000 / 2 = 500 V
Thank you!
Related to Potential difference between two plates
1. What is potential difference between two plates?
Potential difference between two plates is the difference in electrical potential energy per unit charge between the two plates. It is also known as voltage and is measured in volts (V).
2. How is potential difference between two plates calculated?
Potential difference between two plates can be calculated by dividing the work done in moving a unit charge between the two plates by the magnitude of the charge. Mathematically, it is represented as V = W/Q, where V is the potential difference, W is the work done, and Q is the magnitude of the charge.
3. What factors affect the potential difference between two plates?
The potential difference between two plates is affected by the distance between the plates, the magnitude of the charges on the plates, and the medium between the plates. It is also affected by any external sources of electric fields.
4. Why is potential difference important?
Potential difference is important because it is necessary for the flow of electric current. It is also used in various electrical devices and systems, such as batteries, generators, and power grids.
5. How is potential difference related to electric potential energy?
Potential difference is directly proportional to electric potential energy. This means that as the potential difference increases, the electric potential energy also increases. This relationship is described by the equation PE = QV, where PE is the electric potential energy, Q is the charge, and V is the potential difference.
