medguy1234
- 10
The problems tells me to determine the potential difference between between two points. I alrady know that the potential of one point is zero. The problem I am having is that the cirucit has two batteries. I do not have a question so i will describe it, it hsould be easy to visulaize. The first battery is 9V and current I1=3.0A and moves across a resistor R1=2.0 ohms. The second battery is 12.0V and current I2=2.0A and moves across a resitor R2=1.5 ohms. The current then combines at a junction where I1+I2=I3. My question is how to I find the at the junction. I3 flows out of the junction and is5.0A.
V=IR
series and parallel resistor equations
Kirchoff's rule
I caluclated the voltage drop at R1 to be 6.0V, therefore there is 3.0V heading to the junction from I1. I calcualted the voltage drop at R2 to be 3.0V, therefore there is 9.0V heading into the junction from I2. Are the voltages additive? I am not sure bc it would make sense?
are the voltages additive at the point.
