Potential difference between wire and ground
In summary, the conversation is about calculating the potential difference between the surface of a charged wire and the ground, taking into account the line charge density and the distance from the wire to the ground. The method of images is mentioned as a way to replace the ground with a known charge distribution and obtain the potential at ground level. The conclusion is that a wire with opposite linear charge density can be used to achieve a net zero potential at ground level.
timnswede
101
A long, straight power line is made from a wire with radius ra = 1.0 cm and carries a line charge density λ = 2.6 μC/m. Assuming there are no other charges present, calculate the potential difference between the surface of the wire and the ground, a distance of rb = 22 m below.
ΔV= -∫E⋅ds
E due to infinite line of charge: 2kλ/r
what I did was -2kλ∫1/r dr, with limits .01m to 22m. So -2kλ(ln(22/.01). I feel like this might be wrong because I am only taking into account the bottom of the wire aren't I?
I'm pretty sure that's correct. With a sphere, for instance, Gauss's Law means that just outside the surface of the sphere the field is identical to that of a point charge located at the center of the sphere. This problem is the 2D version of that. Instead of a sphere you can think of it as a circle, the cross section of the wire. Just outside of the wire the field should be identical to that of an ideal infinitely-thin wire located at the center of the finite wire.
ΔV= -∫E⋅ds
Aren't you using the field as it would be if no Earth were present?
I get a slightly different result. I used the method of images to replace the ground by another charged object and considered the sum of the potentials.
I'm not sure what the method of images is, we have not done that. Am I supposed to assume the Earth has a charge? We have not done any examples involving the Earth yet either.
OK. I consider the Earth as an infinite flat conducting plate. It has no net charge, but there will be an induced charge distribution.
In the method of images you seek to replace such an infinite sheet by some other body with a known charge distribution. The replacement is valid (above the sheet) provided it produces the same potential everywhere in the plane of the sheet. In this case, a potential of zero.
Given you have this charged wire above the ground, what charged body below the ground would combine with it to result in a net zero potential everywhere at ground level?
Would a wire of opposite linear charge density work, or am I misunderstanding this?
Exactly.
So now you can figure out the potential due to each at any point you like and sum them.
Related to Potential difference between wire and ground
1. What is potential difference between wire and ground?
The potential difference between a wire and ground is the difference in electrical potential energy per unit charge between the two points. It is measured in volts and is a measure of the strength of the electrical field between the wire and ground.
2. How is potential difference between wire and ground calculated?
The potential difference between wire and ground can be calculated by subtracting the electrical potential at the ground point from the electrical potential at the wire point. This is represented by the equation V = Vwire - Vground, where V is the potential difference, Vwire is the potential at the wire point, and Vground is the potential at the ground point.
3. What causes potential difference between wire and ground?
Potential difference between wire and ground is caused by the presence of an electrical field between the two points. This can be due to a difference in charge or voltage between the wire and ground, or due to an external source such as a power supply or battery.
4. What is the significance of potential difference between wire and ground?
The potential difference between wire and ground is important in understanding and analyzing electrical circuits. It helps determine the direction and flow of current, as well as the amount of energy being transferred. It is also essential in ensuring the safety and proper functioning of electrical systems.
5. How does the potential difference between wire and ground affect electrical current?
The potential difference between wire and ground is directly related to the flow of electrical current. A higher potential difference means a stronger electrical field and therefore a higher current flow. Conversely, a lower potential difference means a weaker electrical field and a lower current flow. This relationship is known as Ohm's Law, which states that the current through a conductor is directly proportional to the potential difference and inversely proportional to the resistance of the conductor.
