Potential difference in a simple circuit with transistor
In summary: So you would probably rearrange the equations to..R1=VR1/IbaseR2=VR2/IcollecterIn summary, the conversation discusses the potential difference in a circuit with a transistor, specifically the potential difference across Ry and Rx plus Ry. It is mentioned that the base current should be small compared to the current through Rx and Ry. The conversation also touches on how to find the potential difference of R1 and R2, mentioning the use of the formula V=IR and rearranging the equations to find the values of R1 and R2. It is noted that there is no fixed value for the potential difference across R1 and R2 and it depends on factors such as current and transistor gain. The context and
Adi Hafiz
Hello everyone..I have some difficulties in understanding the potential difference in a circuit with a transistor. Kindly refer to the picture provided. I understood that potential difference across Ry can be obtained from the formula in the picture. The potential difference across Rx plus Ry will be the same as V because I picture it as being parallel to the battery. Please correct me if I'm wrong. But what I would really like to know is how to find potential difference of R1 and R2? Is there any rules that I have to follow? One more thing is it necessary to put R1 in that circuit? I hope someone can answer my questions because I really like to know the answer. http://i.imgur.com/5eI0VkD.jpg
That is correct if you make the assumption that the base current (in R1) is small compared to the current through Rx and Ry. You could make Rx and Ry small compared to R1 so this assumption is valid.
For R1... The base -> emitter of a transistor behaves like a diode so the base voltage will be about 0.7V. You know the voltage at the other end of R1 so you can calculate the voltage difference by subtraction.
For R2... This is harder. If you know the voltage across R1 you can calculate the current flowing through R1 into the base (eg the base current). If you know the gain (HFE) of the transistor you can work out the collector current by multiplying the base current by HFE. Once you know the collector current you can work out the voltage drop across R2.
There are a few complications...
There is a limit on the voltage drop across R2. The collector voltage cannot fall below the saturation voltage of the transistor (perhaps 0.3V). So the drop across R2 cannot be greater than the supply voltage - 0.3V.
The gain of a transistor HFE isn't very well characterised. In other words it varies from transistor to transistor due to manufacturing tolerance. A typical small transistor might have a gain that is specified to be..
min 20
typ 100
max 200
This means the voltage on R2 might vary depending on how good the transistor is. In digital switching circuits it might not be a problem (you could just assume the minimum value). In analogue circuit this problem is typically avoided by including feedback in the design but that's a topic for later when you understand the basics.
Likes Adi Hafiz and davenn
Thanks for the reply CWatters. So from your explanation I conclude that there are no fixed values for potential difference across R1 and R2. It depends on the current I guess? R1 depends on base current and R2 depends on emitter current? Can i use formula V=IR to calculate the potential difference in this case?
VR1=Ibase x R1
VR2=Icollecter x R2
No that's not really what I meant. I'm struggling to answer the question because I don't know the context to the circuit. Where did it come from? What do you think it does? It has no inputs or outputs, nothing is changing so why shouldn't the voltage on R1 and R2 be fixed?
It looks like it might be part of a linear amplifier and I assumed that in my earlier description. In that case it would be normal to choose values for the supply voltage Vcc, the collector and base current and work back to values for R1 and R2.
VR1=Ibase x R1
VR2=Icollecter x R2
The short answer is yes. Although normally when you design a circuit like this those voltages are known and you are trying to calculate what R1 and R2 should be.
Related to Potential difference in a simple circuit with transistor
What is potential difference?
Potential difference, also known as voltage, is the difference in electric potential between two points in a circuit. It is measured in volts (V) and is the driving force that allows electric current to flow through a circuit.
What is a simple circuit?
A simple circuit is a basic electrical circuit that consists of a power source, a load, and conductors connecting the two. It is the most fundamental form of a circuit and is used to demonstrate the principles of electricity.
What is a transistor?
A transistor is a semiconductor device that can amplify or switch electronic signals. It is an essential component in many electronic devices and is used to control the flow of current in a circuit.
How does a transistor affect potential difference in a simple circuit?
A transistor can act as a switch or an amplifier in a circuit, which can affect the potential difference. When a transistor is used as a switch, it can either allow or block the flow of current, which can change the potential difference across the circuit. When a transistor is used as an amplifier, it can increase the strength of the voltage signal in the circuit.
What factors can affect potential difference in a simple circuit with a transistor?
The potential difference in a simple circuit can be affected by various factors, such as the type of power source, the resistance of the load, and the type of transistor. The number and arrangement of components in the circuit can also impact the potential difference.
  • Electromagnetism
