nutzweb
- 12
does anyone knows how to do it? help and pls explain to me... thanks!
1) The slide-wire of a simple potentiometer is 2 meters long and has a resistance of 5 ohms. The emf of the working battery is 6 V and its internal resistance is 0.20 W. What resistance must be added to the working-battery circuit in order for the wire to have a direct reading of 1 mV/mm?
2) A slide-wire potentiometer is balanced against a 1.0182-V standard cell when the slide wire is set at 40.2 cm out of a total length of 100 cm. For an unknown source, the setting is 13. 8 cm. What is the emf of the unknown?
3) Under what condition is a voltmeter more desirable than a potentiometer for the measurement of voltages?
4) Prove that the potentiometer measures the emf of the test cell and not its TPD (hint: use the equation TPD=EMF-Ir).
