Potential Energy and Conservation of Energy
In summary: I'm not sure if I messed up the symbols though... should I be adding the final potential forces instead of subtracting (because we know y is negative)? So it should rather be y=-0.26m?I don't think you should be adding or subtracting anything. You should be setting up an equation that relates the energies (and possibly other quantities) before and after the block is dropped from 2Ho above the spring. You should then solve that equation for the max compression of the spring.So, you have:Eo = EfYou know that Eo = mgho because the block is initially at rest, so there is no kinetic energy. You know that Ef =
fromhuk
A 700g block is released from rest at height Ho(initial) above a vertical spring with spring constant k=400 N/m and negligible mass. The block sticks to the spring and momentarily stops after compressing the spring 19.0 cm.
How much work is done
A) by the block on the spring?
B) by the spring on the block?
C) What is the value of Ho?
D) If the block were released from height 2ho above the spring, what would be the maximum compression of the spring?
W= ΔK
Conservation of Energy:
Eo= Ef
Ug(o) + Us(o) + Ko = Ug(f) + Us(f) +Kf
mgho + 0 (because the spring is not compressed at the start) + 0 (because the initial velocity is 0) = mg(-0.19m) (setting the top of the spring at y=0) + (kx^2)/2 + 0 (because the final instantaneous velocity is 0)
ΣW = Kf - Ko = Ug(o) - Ug(f) - Us(f) = mgho - mg(-0.19m) - 7.22J
I am mainly struggling with the conceptual part... for (a), the work done is only the compression of the spring, not the total work, right? So, it would be 7.22J. And (b) would be negative because the block is exerting force on the spring, and the spring is experiencing work that it can later convert into its own form of work?
For (c), solving Ug(o) + 0 + Ko = Ug(f) + Us(f) +Kf for ho:
W = mgho - 7.22J - mg(-0.19m) = 0
ho + (0.19m) = 7.22J/6.86N
ho = 0.86meters
For (d):
W = 2mgho - (k(x^2)/2) - mg(-0.19m) = 0
x^2 = 2(13.10J)/400N/m
x = 0.26meters
If someone could help explain work vs. forces vs. energy as it relates to this problem it'd be much appreciated!
Welcome to PF fromhuk!
H0 is the initial distance of the block from the top of the uncompressed spring. The total distance the block falls, therefore is ________.
When the spring is compressed to 19 cm from its original state, is there any kinetic energy in the system (spring + block)? What is the potential energy stored in the spring at that point? What is the change in potential energy of the block? Set up an equation that relates the energies and you will be able to solve this.
Work is defined as: ##W = \int \vec{F}\cdot d\vec{s}##. The block applies a downward force on the spring as it moves downward, so the directions of the force and displacement are the same. Therefore, the block does positive work on the spring. The spring, however, applies an upward force on the block as the block moves downward, so the force and the displacement through which that force acts have opposite signs. This means the spring does negative work on the block.
AM
AM
ho + 0.19m, however, I set the top of the spring as y=0, so those extra 0.19m do not have to be included in the gravitational potential energy, right?
I don't see why there'd be kinetic energy in the system when the spring is compressed- the block is not moving and the spring has potential energy Us: 7.22J, what am I missing? The change of potential energy in the block would be Kf - Ki + Uf - Uo = -Us; -7.22J.
PS. Thanks for the help!
Right. The block exerts a force on the spring, which compresses the spring. The work done by the block is stored as potential energy by the spring.
Newton's third law says if the block exerts a force on the spring, the spring exerts an equal and opposite force on the block, so the work done by the block on the spring and the work done by spring on the block will always be related by a minus sign.
W = mgho - 7.22J - mg(-0.19 m) = 0
ho + (0.19 m) = 7.22 J / 6.86 N
ho = 0.86 meters
That's what I get too.
For (d):
x = 0.26meters
Why do you have mg(-0.19 m) in there? Is that still relevant when the block is dropped from twice the height above the spring?
You should stick with one variable, either x or y, for the vertical direction. You say the top of the spring is at y=0, but then you describe the compression of the spring as x. Pick one and stick with it.
Thanks! You are right, of course. I have it down with "y"s rather than x, and that 0.19m as a y instead.
I did 2mgho - (ky^2)/2 - mgy
Solving for y:
y=0.23meters
Solving for y:
y=0.23meters
That is not an equation. You should explain your reasoning. Where does the 2 in 2mgho come from? y is the compression distance, which you are given (.19 m).
If you meant: ##mg(h_0 + y) = \frac{1}{2}ky^2## that would be correct. I get .86 m for h0
AM
fromhuk said:
Should I be adding the final potential forces energies instead of subtracting (because we know y is negative)? So it should rather be y=-0.26m?
It depends on how you define ##y##. If you define it to be the distance the spring is compressed and hence assume that ##y>0##, the final gravitational potential energy would be ##mg(-y)##, and you'd choose the positive root of the quadratic. If instead you take ##y## to be the displacement of the block, you'd use ##mgy##, and you'd choose the negative root because the other root would be a spurious solution corresponding to a point above the spring.
Related to Potential Energy and Conservation of Energy
1. What is potential energy?
Potential energy is the energy that an object possesses due to its position or configuration. It is the energy that an object has stored and can be converted into other forms of energy, such as kinetic energy.
2. How is potential energy related to the conservation of energy?
According to the law of conservation of energy, energy cannot be created or destroyed, only transferred or converted from one form to another. Potential energy is a form of energy that can be converted into other forms, such as kinetic energy, without violating this law.
3. What are some examples of potential energy?
Some examples of potential energy include a stretched rubber band, an object at the top of a hill, a compressed spring, and a book held above the ground. These objects have the potential to do work when released or allowed to move.
4. How can potential energy be calculated?
The formula for potential energy is PE = mgh, where PE is potential energy, m is the mass of the object, g is the acceleration due to gravity, and h is the height of the object. This formula applies to objects near the surface of the Earth.
5. Can potential energy be negative?
Yes, potential energy can be negative. This usually occurs when an object is in a position lower than its reference point, such as an object below ground level or a negative height. In these cases, the potential energy is considered to be negative relative to the reference point.
