Potential Energy and raising a satellite from Earth into a Circular Orbit
In summary: You may want to double check your calculations to make sure they are accurate, but the steps and formulas you used are correct. Also, make sure to include appropriate units in your final answers. Great job summarizing the conversation!In summary, the conversation discussed various calculations involving gravitational potential, energy, and velocity of a satellite orbiting the Earth. The formulas V=-GM/r and v orbit = √GM/r were used to find the gravitational potential and orbital velocity at different distances from the Earth's surface. The difference in gravitational potential was calculated using the formula ΔU=Uorbit−UEarth, and the total energy of the satellite was found by adding its kinetic energy and potential energy. It was then verified that the change in total energy was
AN630078
242
25
Hello, I have quite a lengthy, but assuredly related question where each section leads onto the next. I have been trying to better understand potential energy and the mechanisms of circular orbits when I came across the problems below. Would anyone be able to scrutinise my calculations and evaluate my workings, to perhaps suggest a preferable approach. For instance in hindsight would it have been better if I had applied Newton's Second Law, ΣF = ma,
which becomes GmM/r2 = mv2/r. Then continued to derive formula in terms of potential and kinetic energy? Thank you to anyone who replies, apologies for the length, although they are related questions, ie to find the kinetic energy one must first establish the value of the orbital velocity. 😁
The radius of the Earth is 6.4 x 10^6 m and its mass is 6.0 x 10^24 kg.
Question 1:
a.What is the gravitational potential at the surface of the Earth?
b.What is the gravitational potential 200 km above the Earth’s surface?
c. How much energy would be needed to move a satellite of mass 3000 kg from the Earth’s surface to a height of 200 km?
d. At what speed would a satellite 200 km above the Earth’s surface be moving?
e. If its mass were 3000 kg how much kinetic energy would it have?
f. What total energy is needed to set a satellite of mass 3000 kg in orbit 200 km above the Earth?
V grav= -GM/r
E=U+K
v=√GM/r
a. V=-GM/r
V=-6.67*10^-11*6.0 x 10^24/6.4 x 10^6
V grav = -62531250 ~ -62.5M Jkg^-1
b. To find the gravitational potential 200 km above the surface of the Earth;
r=6.4 x 10^6 +2*10^5 m=6.6*10^6
V grav=-6.67*10^-11*6.0 x 10^24/6.6*10^6
V grav= -60636363 ~ -60.6 M Jkg^-1
Can I check that it is correct that these values are negative?
c. To find the energy required to move a satellite to a height of 200km above the surface of the Earth find the difference in the gravitational potential;
ΔU=Uorbit−UEarth
U Earth = -GMm/r
U Earth = - 6.67*10^-11*6.0 x 10^24*3000/ 6.4 x 10^6
U Earth = -1.8759375 * 10^11 J~ -1.87* 10^11 J
U orbit = -GMm/r + 2.0*10^5 m
U orbit = - 6.67*10^-11*6.0 x 10^24*3000/ 6.6 x 10^6
U orbit = -1.819090 *10^11 J ~ -1.82 *10^11 J
ΔU=( -1.82 *10^11)-( -1.8759375 * 10^11)
ΔU=5684659091 ~ 5700000000 J = 5700 MJ
Are units of J or MJ suitable her or should it be Jkg^-1?
d. To find the orbital velocity use the formula;
v orbit = GM/r
v orbit = 6.67*10^-11*6*10^24/6.6*10^6
v orbit =7786.935446 ~ 7790 ms^-1 to 3.s.f
e.The kinetic energy of the satellite on the surface of the Earth is 0 J.
The kinetic energy of the satellite 200 km above the Earth's surface is;
K orbit = 1/2mv^2
K orbit = 1/2 * 3000*7790^2
K orbit = 9.1 * 10 ^10 J to 2.s.f
KE total = K Earth + K orbit
KE total = 0 J + 9.1 * 10 ^10 J=9.1 * 10 ^10 J
This can be verified by subtracting the change in potential energy from the total energy.
f. E total=K1+U1=K2+U2
The total energy required is the difference in the satellite's energy in orbit and that at Earth’s surface.
E orbit = K orbit + U orbit
E orbit= 9.1 * 10 ^10 + (-1.819 *10^11)= -9.1 * 10^10 J
E surface = K Earth + U Earth
E surface = 0 + (-1.87* 10^11)=-1.87* 10^11 J
Δ𝐸= E orbit - E surface
Δ𝐸=-9.1 * 10^10-(-1.87* 10^11)
Δ𝐸=9.66392 * 10^10 ~ 9.66 *10^10 J
Re b), calculating the additional GPE of GPE200km-GPE0 by taking the difference of those two large numbers tends to produce a significant error in the answer. To avoid keeping lots of digits, it is better to do a bit of algebra first:
##\frac{GMm}{r_{200}}-\frac{GMm}{r_0}=-GMm(\frac{1}{r_{0}}-\frac{1}{r_{200}})=-\frac{GMm}{r_0r_{200}}200##
Thank you for your reply. Yes I have seen this formula before but I was unsure how to derive it. Thank you for the suggestion👍 Are there any other improvements I could make?
Only at the poles.
haruspex said:
Only at the poles.
Thank you again so would the rest of my workings be correct also? I will use the formula you suggested in b also, thank you again for providing that 😁
Yes, it's fine.
Related to Potential Energy and raising a satellite from Earth into a Circular Orbit
1. What is potential energy?
Potential energy is the energy that an object possesses due to its position or configuration. It is stored energy that has the potential to be converted into other forms of energy, such as kinetic energy.
2. How is potential energy related to raising a satellite into a circular orbit?
In order to raise a satellite from Earth into a circular orbit, potential energy must be converted into kinetic energy. This is done by applying a force, such as a rocket engine, to the satellite, which increases its potential energy and allows it to move into a higher orbit.
3. What factors affect the potential energy of a satellite in orbit?
The potential energy of a satellite in orbit is affected by its mass, its distance from the center of the Earth, and the gravitational force between the satellite and the Earth. The higher the mass and the further the distance, the greater the potential energy.
4. How is the potential energy of a satellite in a circular orbit calculated?
The potential energy of a satellite in a circular orbit is calculated using the formula PE = -GMm/r, where G is the gravitational constant, M is the mass of the Earth, m is the mass of the satellite, and r is the distance between the satellite and the center of the Earth.
5. Can the potential energy of a satellite in orbit be changed?
Yes, the potential energy of a satellite in orbit can be changed by altering its mass or its distance from the Earth. This can be done through the use of thrusters or other propulsion systems to change the satellite's speed and trajectory, thus altering its potential energy.
