Potential energy equation to force equation?
The discussion revolves around deriving the force equation from the Morse potential energy formula for a diatomic molecule, specifically N2. The potential energy is given by U(r) = De (1-e^[-a(r-re)])², where De is the well depth, a is the width of the well, r is the atomic separation, and re is the equilibrium distance. The attempted force expression, F = 2aDe[e^(-2a(r-re)) - e^(-a(r-re))], is questioned for a potential sign error, as it was marked incorrect in an online homework submission. Participants are focused on identifying the source of the sign error in the derived force equation. The conversation emphasizes the importance of correctly applying the derivative in the context of potential energy to force conversion.
MattNguyen
The binding potential energy in a diatomic molecule (N2 for example) is often approximated by the Morse potential energy which has the form U(r) = De (1-e^[-a(r-re)])2 where De is a constant that reflects the well depth (dissociation energy), a is a constant that reflects the width of the well, r is the distance between the atoms, and re is the equilibrium distance. Input an expression for the force as a function of the separation distance (r).
F=-du/dx
F=2a*De*[e^(-2a(r-re))-e^-(a(r-re))]
I'm just unsure about the re part. I feel like I'm almost correct.
F=-du/dx
Looks ok except for the sign.
Which sign? I entered it into my online homework and it was wrong so that's why I'm asking.
Seems to be correct.
Now I have this
2 a De ( Exp ( - 2 a ( r - re ) ) - Exp ( - a ( r -| re ) ) )
and I inputted it and it says there's a sign error. I just have no idea where,
  • · Replies 24 ·
