Potential Energy = Kinetic Energy
In summary, the average student doesn't understand why Ke=Pe and assumes that they are the same. However, this isn't always the case and Kinetic energy and potential energy can't always be equal. This is why the average student struggles with using basic physics concepts.
Ohm
Even the average student can assume in cases where a tennis ball falls freely or is hit that Ke = Pe.
The question is why do we take it as if they are equal?
Average students probably assume a lot of things that aren't correct. It certainly isn't the case that "where a tennis ball falls freely or is hit that Ke= Pe". As a tennis ball falls its Kinetic energy is increasing and its Potential energy is decreasing. They can't always be the same. In addition, while kinetic energy depends upon speed, potential energy is always relative to some arbitrary reference point. Because of that you can always take potential energy to be equal to kinetic energy as some specific time but they won't stay equal.
Thanks.
What can be equal in those ideal cases is that the change in potential energy = - change in kinetic energy. This comes from the fact that you are dealing with conservatory forces and therefore the total energy is conserved (total energy = kinetic energy+potential energy). Therefore, since the total energy is a constant, if the potential energy goes down, then the kinetic energy goes up (case of a tennis ball falling freely).
To say it in a different way, kinetic energy at impact equals potential energy at release for a dropped tennis ball. This is true if you make some assumptions such as no wind resistance.
Yup, energy is conserved in isolated systems. Thanks for the insight. Would you believe that i finished Mechanics A-level at school(Average mark 87.5%) and i was not familiar with the reason of equating Loss in Pe with Gain in Ke ? Lately i discovered that i was not familiar with basic physics - I relied heavily on memory when i was doing O-level. In fact, i discovered that the majority of my friends who are doing A-level physics know everything by heart. I mean I can solve simple "critical" questions but when it comes to using basic theory to "extract" an idea, well that's where I get stuck.
Most Uncanny though, is the fact that i managed to get through Mechanics A-level incredibly successfuly. I'm currently searching on the internet to get my self obtained with basic information and get puzzled with questions. I'm going to be using your forums since i do not consider internet to be a perfectly reliable source.
FAQ: Potential Energy = Kinetic Energy
What is potential energy and kinetic energy?
Potential energy is the energy that an object possesses due to its position or state. Kinetic energy is the energy an object has due to its motion.
How are potential energy and kinetic energy related?
Potential energy can be converted into kinetic energy, and vice versa. For example, when an object is dropped from a height, its potential energy is converted into kinetic energy as it falls.
How is potential energy calculated?
Potential energy is calculated by multiplying an object's mass by its height above the ground and the acceleration due to gravity (9.8 m/s^2). The formula is PE = mgh, where PE is potential energy, m is mass, g is acceleration due to gravity, and h is height.
How is kinetic energy calculated?
Kinetic energy is calculated by multiplying an object's mass by its velocity squared and dividing by 2. The formula is KE = 1/2 mv^2, where KE is kinetic energy, m is mass, and v is velocity.
Can potential energy and kinetic energy be converted into other forms of energy?
Yes, potential energy and kinetic energy can be converted into other forms of energy, such as thermal energy or sound energy. This is known as the principle of energy conservation, which states that energy cannot be created or destroyed, only converted from one form to another.
