wooram83
- 2
1. A cylinder, of mass 2 kg, and a radius of 1 m, starts from rest, at point A, with its axis 3.5m above a flat stretch of ground, then rolls down a 30 degree slope as shown. After rolling a few meters horizontally, it rolls up another 30 degree slope and emerges on a flat surface 2 m above the
ground, still rolling.
Assuming no loss to friction, and the acceleration of gravity is 9.80 m/s2:
a) Find the kinetic and potential energy of the cylinder at point A
b) Find the kinetic and potential energy of the cylinder at point B
c) Find the kinetic and potential energy of the cylinder at point C
Be sure to define the origin of potential energy (where PE = 0)
d) Find the linear and angular velocity of the cylinder at point A
e) Find the linear and angular velocity of the cylinder at point B
f) Find the linear and angular velocity of the cylinder at point C
I=1/2MR^2
a) KE=0, PE=68.6J
b) PE=0, KE=68.6J
c) PE= 39.2J, KE=29.4J
d) both=0
e) w=6.8 rad/s, v=6.8 m/s
f) w=5.1 rad/s, v=5.1m/s
I wasn't sure where to base the height on this question for the potential energy. The book says I have to measure from the center of mass but when the ball is on the ground the center of mass is located 1m above the ground. Do I still consider this Potential Energy zero or do I need to put 1m as the height? If I consider this to be zero at the ground than do I measure the original Potential Energy at the bottom of the ball? Please check my other work as well.
I=1/2MR^2
a) KE=0, PE=68.6J
b) PE=0, KE=68.6J
d) both=0
