Potential Energy Problem: Pulling a Chain up onto a Table
  • Thread starter Thread starter Ascendant0
    Mass
The discussion focuses on understanding the formula for calculating the mass of a segment of a chain, specifically why the total mass "m" is divided by the total length "L." The confusion arises from the implication that a smaller "L" would lead to an infinite mass for an infinitesimally small segment. However, it is clarified that the mass of a segment does not depend on the total length of the chain; if "L" is halved, both "m" and the ratio remain consistent. The formula indicates that the mass of a segment is proportional to its length relative to the total length, ensuring that the mass remains finite. The participant expresses gratitude for the clarification and plans to revisit the problem with a better understanding.
Ascendant0
A chain is held on a frictionless table with one fourth of its length hanging over the edge. If the chain has length L = 0.28 m and mass m = 0.012 kg, how much work is required to pull
the hanging part back onto the table?
Potential energy dU
So, the first thing that came to mind when I was trying to figure out how to set this up is that it will be a dU problem. After trying to figure out how to set it up to no avail, I took a look at how they solved it in the solutions manual. It's making absolutely no sense to me...
They state "note that the mass of a segment is (m/L) dy". I'm completely lost on that part, as to why "L" is in the denominator? Wouldn't that setup mean that the smaller "L" is, the larger the mass, to the point where it becomes infinite if it is infinitesimally small??? I'm not seeing the sense behind how they've set it up, as from what I'm thinking, they're basically stating the shorter the length, the larger the mass. Can someone help me to view this correctly so I can understand why it is set up the way it is?
It shows the dependence between the mass and the length, which can be expressed as kg/m, for example.
Since length L = 0.28 m and mass m = 0.012 kg, we can say that this chain has a linear mass of 0.012/0.28 = 0.0428 kg/m.
Likes scottdave and Ascendant0
The total length of the chain is ##L## and the total mass is ##m##. If ##\Delta y## is the length of a segment of the chain, the mass of this segment is a fraction of the total mass ##m##. For example, suppose ##\dfrac {\Delta y} L## is ##\dfrac1 {10}## so that ##\Delta y## is one-tenth of ##L##. In this case, the mass of the segment ##\Delta y## will be ##\dfrac1 {10}## of the total mass ##m##. That is, $$(\text{mass of segment of length } \Delta y) = \frac {\Delta y} L \cdot m$$ This can be rewritten as $$(\text{mass of segment of length } \Delta y) = \frac m L \cdot \Delta y$$
For a given type of chain, the mass of a segment of length ##\Delta y## does not depend on the total length ##L## of the chain. If ##L## were cut in half, the total mass ##m## would also be reduced by one-half. But the ratio ##\dfrac m L## would not change. So, according to the formula above, the mass of a segment ##\Delta y## is not changed when ##L## is changed.
Likes Lnewqban and Ascendant0
Thanks to both of you. I get it now. It's a little late for me to get back to the problem, but I'm going to revisit it tomorrow and make sure it all makes sense now. I believe it should. I appreciate the help, thank you
Likes TSny and Lnewqban
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
