Potential energy. What is the spring constant?
In summary, the conversation discusses a problem involving a stone at rest on a compressed spring. The spring constant is determined using the formula k=2mg/h. However, the answer turns out to be half of the expected value. After further discussion, it is realized that the energy balance equation used by the student is not applicable for the given situation. The correct formula for the spring constant is k=2mg/h^2.
Y*_max
Figure 8-36 shows an 8.00 kg stone at rest on a spring. The spring is compressed 10.0 cm by the stone. (a) What is the spring constant?
2. Relevant formula
Mechanical energy is conserved
The decrease in gravitational potential energy that occurs when the block is put on the spring (the spring is compressed) is equal to the increase in elastic potential energy of the spring.
Thus: mgh=0.5kh^2 (the coordinate system is chosen so that gravitational potential energy is zero when the block is at rest and the spring is compressed)
Solving the equation for k gives k=2gm/h
k=2*9.8*8.0/0.1=1568 N/m.
Yet, the answer turns out to be 784N/m :/
What did I do wrong?
Thanks!
The downward force on the force is equal to mg.
The restoring force by the spring in opposite direction is kx, equating
8g=k/10
K=9.8*8*10=784N
AbhinavJ said:
8g=k/10
K=9.8*8*10=784N
its 10 cm so you should take 0.1m , And you missed a factor of 2
not necessarily true! There is no diagram! Anyway, try equating mg = kx , you won't get the same answer! Was the body dropped suddenly or slowly lowered down to equilibrium?
Max' question "what did I do wrong ?" still stands !
You did an energy balance for a situation where all potential energy from gravity is converted into mechanical energy to compress the spring.
That would be: let go of the stone at the top of the uncompressed spring and see where the mass stops moving (i.e. the motion reverses direction). However, at that point the energy in the spring is enough to push the stone back to the original postition (again with potential energy mgh and no kinetic energy) where the sequence would repeat.
That is not what was given in the exercise. The stone was lowered gently until equilibrium position. The hand that lowered the stone took away half the potential energy.
Likes AbhinavJ
Suraj M said:
it's ## k=\frac{2mg}{h^2}##
No, it definitely is not. Max did the ##
k=\frac{2mgh}{h^2}## just fine, only the energy balance didn't apply for the situation described.
Likes AbhinavJ
BvU said:
No, it definitely is not. Max did the k=2mghh2 k=\frac{2mgh}{h^2} just fine, only the energy balance didn't apply for the situation described.
I realized that 12 mins ago,BvU :smile: changed it, sorry!
Oh, I see! Thank you very much to you all!
Related to Potential energy. What is the spring constant?
1. What is potential energy and how is it related to spring constant?
Potential energy is the energy possessed by an object due to its position or configuration. The spring constant is a measure of the stiffness of a spring and is directly related to the amount of potential energy stored in the spring. A higher spring constant means a stiffer spring and therefore a greater potential energy.
2. How is the spring constant calculated?
The spring constant is calculated by dividing the force applied to a spring by the amount of deformation it experiences. It is represented by the letter "k" and has units of Newtons per meter (N/m).
3. Can the spring constant change for a given spring?
Yes, the spring constant can change for a given spring. It is affected by factors such as the material and thickness of the spring, as well as the temperature and any external forces acting on the spring.
4. How does the spring constant affect the potential energy of a spring?
The spring constant directly affects the amount of potential energy stored in a spring. A higher spring constant means a stiffer spring and therefore a greater potential energy. Conversely, a lower spring constant means a less stiff spring and therefore a lower potential energy.
5. Can the spring constant affect the oscillation frequency of a spring?
Yes, the spring constant does affect the oscillation frequency of a spring. A higher spring constant will result in a higher frequency of oscillation, while a lower spring constant will result in a lower frequency of oscillation.
