Potential Flow Theory: Circulation and the Kutta-Jukowski Theorem
In summary, the convention for ## \Gamma ## is that it represents the circulation around a body in potential flow, and the Kutta-Jukowski theorem states that the lift produced by a body is proportional to the circulation.
Master1022
611
117
Homework Statement:: What is the convention for ## \Gamma ## for the streamline ## \Psi = \frac{\Gamma}{2\pi} ln(\frac{r}{a} ) ## and how can we interpret the Kutta-Jukowski Theorem?
Relevant Equations:: ## v_{\theta} = - \frac{\partial \Psi}{\partial \theta} ##
[Mentor Note -- moved from the schoolwork forums to the Aerospace forum]
Hi,
I just had a quick question about conventions in potential flow theory:
Question: What is the convention for ## \Gamma ## for the streamline ## \Psi = \frac{\Gamma}{2\pi} ln(\frac{r}{a} ) ## and how can we interpret the Kutta-Jukowski Theorem ## Lift = - \rho U \Gamma ##?
Approach:
For the first part, am I correct in thinking that ## \Gamma ## indicates a clockwise circulation? This is supported by the fact that
$$ v_{\theta} = - \frac{\partial \Psi}{\partial \theta} = - \frac{\Gamma}{2 \pi r} $$
where ## \theta ## is defined to be defined as anti-clockwise from the +ve x axis. I was confused as I had seen diagrams on the internet where they have suggested that ## + \Gamma ## indicates an anticlockwise circulation. Another quick question I have is: is gamma the circulation of the fluid or the cylinder? If it's the former, does that mean that if the cylinder is rotating (e.g. CW) we take the circulation as being of equal 'strength' in the CCW direction?
For the second part, I have done the integration to get the result that ## Lift = - \rho U \Gamma ## where Lift has been defined in the +ve y-direction. However, I don't think I really understand what this means. So this formula predicts that there will be a positive lift in the y-direction when there is an anticlockwise circulation?
Any help would be greatly appreciated
Answer:
The convention for ## \Gamma ## is that a positive value indicates a clockwise circulation, and a negative value indicates an anticlockwise circulation. This is supported by the fact that the equation
implies that a positive value of ## \Gamma ## will result in a negative value of ## v_\theta ##, which indicates an anticlockwise flow.
The Kutta-Joukowski Theorem states that the lift produced by a body in a fluid is equal to the circulation of the fluid times the density of the fluid times the velocity of the body. This can be written mathematically as
$$ Lift = - \rho U \Gamma $$
where ## \rho ## is the fluid density, ## U ## is the body velocity, and ## \Gamma ## is the circulation of the fluid. This theorem implies that a positive value of ## \Gamma ## (indicating a clockwise circulation) will produce a positive lift in the y-direction.
. Thanks!
Hi there,
In potential flow theory, the convention for ## \Gamma ## is that it represents the strength of the vortex or circulation around a body. This means that a positive ## \Gamma ## indicates a clockwise circulation, while a negative ## \Gamma ## indicates an anticlockwise circulation.
In the streamline equation ## \Psi = \frac{\Gamma}{2\pi} ln(\frac{r}{a} ) ##, ## \Gamma ## is the circulation of the fluid around the cylinder. This means that if the cylinder is rotating clockwise, the circulation will be in the counterclockwise direction.
The Kutta-Jukowski theorem states that the lift generated by a body in potential flow is proportional to the circulation around the body. In other words, the greater the circulation around the body, the greater the lift. So in the case of an anticlockwise circulation, there will be a positive lift in the y-direction.
I hope this helps clarify things for you. Let me know if you have any other questions.
Related to Potential Flow Theory: Circulation and the Kutta-Jukowski Theorem
1. What is potential flow theory?
Potential flow theory is a mathematical model used to describe the motion of fluids, specifically incompressible and inviscid fluids. It assumes that the flow is irrotational, meaning that the fluid particles do not rotate as they move, and that the flow is governed by the principles of conservation of mass and energy.
2. What is circulation in potential flow?
Circulation in potential flow refers to the motion of fluid particles around a closed path in the flow. It is a measure of the strength of the vortex created by the flow around a body, and is related to the lift force generated by the body.
3. How is circulation related to the Kutta-Jukowski theorem?
The Kutta-Jukowski theorem states that the lift force on an airfoil is proportional to the circulation around the airfoil. This means that by controlling the circulation, we can control the lift force on the airfoil. The Kutta-Jukowski theorem is a fundamental principle in aerodynamics and is derived from potential flow theory.
4. Can potential flow theory be applied to all types of fluids?
No, potential flow theory is only applicable to incompressible and inviscid fluids, meaning that they do not change in density under flow and have no internal friction. Real fluids, such as air and water, do not completely satisfy these conditions, but potential flow theory is still useful in providing a simplified understanding of fluid flow.
5. What are some limitations of potential flow theory?
Potential flow theory has several limitations, including its inability to accurately predict drag forces, boundary layer separation, and other complex flow phenomena. It also does not account for the effects of viscosity and compressibility, which are important in real-world fluid flow situations. Therefore, potential flow theory should be used with caution and only as a starting point for more detailed analysis.
  • Classical Physics
  • Classical Physics
