POTW #386: Evaluate (a+b+c)(b+c+d)(c+d+a)(d+a+b) for x^4-7x^3+3x^2-21x+1=0
  • MHB
  • Thread starter anemone
In summary, the given polynomial equation is x^4-7x^3+3x^2-21x+1=0 and the requested evaluation is for (a+b+c)(b+c+d)(c+d+a)(d+a+b). The purpose of evaluating this polynomial expression is to find the values of a, b, c, and d that satisfy the given equation. The order of operations for evaluating this expression is to first expand the expression using the FOIL method, then combine like terms, and finally substitute the given polynomial equation for x. To solve this equation, you can use algebraic methods such as factoring, the quadratic formula, or synthetic division. Once you have found the values of a, b, c
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Given $a,\,b,\,c,\,d$ are roots of the equation $x^4-7x^3+3x^2-21x+1=0$.
Evaluate $(a+b+c)(b+c+d)(c+d+a)(d+a+b)$.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution!(Cool)
1. MegaMoh
2. kaliprasad
3. castor28
4. lfdahl
5. Opalg
Solution from Opalg:
If $a,b,c,d$ are the roots of $p(x) = x^4-7x^3+3x^2-21x+1$ then $a+b+c+d=7$. Also, $p(x) = (x-d)(x-a)(x-b)(x-c).$ Therefore $$(a+b+c)(b+c+d)(c+d+a)(d+a+b) = (7-d)(7-a)(7-b)(7-c) = p(7) = 7^4-7*7^3+3*7^2-21*7+1 = 1.$$
Alternate solution from castor28:
Let us call $P$ the expression to be computed. As this is a symmetric polynomial, we will use the notation $[M]$, where $M$ is a monomial, to represent the sum of the distinct monomials obtained from $M$ by permuting the indeterminates in all possible ways (this is called an orbit sum). We choose as representative of each class the monomial that comes first in lexicographic order. In a polynomial, we order the orbit sums in lexicographic order.
The advantage of this technique is that, when doing polynomial arithmetic, we only need to compute the coefficient of the representative of each class.
As the polynomial is homogeneous of degree $4$, the only orbit sums involved are $[a^4]$ (which does not actually appear), $[a^3b]$, $[a^2b^2]$, $[a^2bc]$, and $[abcd]$.
We will express the polynomial in terms of the elementary symmetric polynomials:
\begin{align*}
s_1 &= a + b + c + d = [a] = 7\\
s_2 &= ab + ac + ad + bc + bd + cd = [ab] = 3\\
s_3 &= abc + abd + acd + bcd = [abc] = 21\\
s_4 &= abcd = [abcd] = 1
\end{align*}
where the values are obtained using Viète's relations.
The given polynomial is $P = [a^3b] + 2[a^2b^2] + 4[a^2bc] + 9[abcd]\ $; the coefficients are found by computing the number of possible ways to obtain the representative of each orbit sum.
Since the leading term $a^3b$ only contains two variables, we can produce it using $s_1$ and $s_2$. Specifically, we have:
\begin{align*}
s_1^2s_2 &= (a + b + c + d)^2(ab + ac + ad + bc + bd + cd)\\
&= [a^3b] + 2[a^2b^2] + 5[a^2bc] + 12[abcd]
\end{align*}
We obtain, after simplification:
P - s_1^2s_2 = -[a^2bc] - 3[abcd]
Since the leading term $-a^2bc$ only uses three variables, we use $s_1$, $s_2$, and $s_3$ to cancel it. We obtain, after some work:
\begin{align*}
s_1s_3 &= [a^2 b c] + 4[a b c d]\\
P - s_1^2s_2 + s_1s_3 &= [abcd] = s_4
\end{align*}
and this gives:
\begin{align*}
P &= s_1^2s_2 - s_1s_3 + s_4\\
&= 7^2\times 3 - 7\times 21 + 1\\
&= \mathbf{1}
\end{align*}
FAQ: POTW #386: Evaluate (a+b+c)(b+c+d)(c+d+a)(d+a+b) for x^4-7x^3+3x^2-21x+1=0
What is the value of (a+b+c)(b+c+d)(c+d+a)(d+a+b) when x^4-7x^3+3x^2-21x+1=0?
The value of (a+b+c)(b+c+d)(c+d+a)(d+a+b) when x^4-7x^3+3x^2-21x+1=0 cannot be determined without knowing the values of a, b, c, and d. The equation x^4-7x^3+3x^2-21x+1=0 only provides the values of x, not the other variables.
How can I solve for a, b, c, and d in the equation x^4-7x^3+3x^2-21x+1=0?
The equation x^4-7x^3+3x^2-21x+1=0 cannot be solved for a, b, c, and d as there are four variables but only one equation. More information is needed to solve for the values of a, b, c, and d.
Can I use the quadratic formula to solve for a, b, c, and d in the equation x^4-7x^3+3x^2-21x+1=0?
No, the quadratic formula can only be used to solve equations with one variable raised to the second power. The equation x^4-7x^3+3x^2-21x+1=0 has four variables raised to different powers, so the quadratic formula cannot be applied.
Is there a specific method or formula to solve equations with multiple variables like x^4-7x^3+3x^2-21x+1=0?
Yes, there are several methods for solving equations with multiple variables, such as substitution, elimination, and graphing. However, these methods require additional information or equations to solve for all the variables.
Can I use a calculator to solve for a, b, c, and d in the equation x^4-7x^3+3x^2-21x+1=0?
No, a calculator cannot solve for variables in an equation. It can only perform calculations with given values. To solve for a, b, c, and d in the equation x^4-7x^3+3x^2-21x+1=0, more information or equations are needed.
