- 10,797
- 3,666
Hi All
Read a thread that about Von-Neumann observations that was closed because it was a bit too vague, but I sort of got a sense of what the poster was on about - and it also is interesting anyway for anyone that doesn't know it so I thought I would do a post about it.
Since Von-Neumann's time a lot of work has been done on measurements eg:
http://www.quantum.umb.edu/Jacobs/QMT/QMT_Chapter1.pdf
It turns out that what Von-Neumann wrote in his classic text on QM about measurements has now been generalized from Von-Neumann measurements to what are called POVM's.
Here is a summary.
First we need to define a Positive Operator Value Measure (POVM). A POVM is a set of positive operators Ei ∑ Ei =1 from, for the purposes of QM, an assumed complex vector space.
The basic measurement postulute of QM is an observation/measurement with possible outcomes i = 1, 2, 3 ... is described by a POVM Ei such that the probability of outcome i is determined by Ei.
In fact from that alone and non-contextuality (ie the probability is not affected by what POVM it is part of) you can derive the Born Rule.
This is observation in the form of its modern generality. Von-Neumann used a subset of this and to understand it we need to define what is called a resolution of the identity, which is POVM that is disjoint ie if you take any two elements of the POVM A and B then AB=0. Such are called Von-Neumann observations. We know from the Spectral theorem Hermitian operators, H, can be uniquely decomposed into resolutions of the identity H = ∑ yi Ei. So what we do is given any observation based on a resolution of the identity Ei we can associate a real number yi with each outcome and uniquely define a Hermitian operator O = ∑ yi Ei, called the observable of the observation.
But as the link I gave shows, by use of a probe to observe something then observing the probe you are forced to generalize Von-Neumann measurements to POVM's so that is the modern view of a measurement. Of course once you do that you can't always form an operator of the measurement because it may no longer be a resolution of the identity.
Thanks
Bill
Here is a summary.
Thanks
Bill
