Power absorbed and B vs H plot for microwave oven transformer
In summary, a DI-149 data acquisition module was used to record the time histories of voltage and current for an open secondary microwave oven transformer (MOT) at 90v, 100v, 110v, and 120v rms. The DI-149 has a full scale range of +-10 volts and a ten bit ADC, with two channels being recorded at 5000 samples per second. The power absorbed by the MOT can be calculated using the real voltage and current at time t, and the time integral of V(t)I(t) over one period gives the net energy absorbed. A B vs H plot was constructed using the data, showing that the MOT saturates at around 110v rms and has a non
Russ Edmonds
TL;DR Summary
Net power absorbed and a tentative B vs H plot for an unloaded microwave oven transformer (MOT)
A DI-149 data acquisition module was used to record a microwave oven transformer (MOT) primary voltage and current time histories. The secondary of the MOT was open. The DI-149 analog input specs are: +- 10 volts full scale, 5000 samples per second for each channel (assuming two channels being recorded) and a ten bit ADC. One second of data was was recorded for 90v, 100v, 110v and 120v rms.The setup.
Note: The MOT HV cap is not in the circuit. One terminal of this cap is being used as a connection point for the blade/push on connectors.
Schematic of the setup.
The power absorbed by the MOT at time t is given by V(t)I(t) where V(t) and I(t) are the real voltage and current at time t. The current lags the voltage by nearly 90 degrees so this term shows that the MOT alternatively absorbs and emits power. The time integral of V(t)I(t) over one period of the AC cycle (T) gives the net energy absorbed by the MOT in one T. Dividing the net energy by T then gives the net power absorbed.
Magnetic flux density in the core is given by the time integral of voltage divided by the number of primary turns and cross sectional area of the core at the primary winding. There can also be a constant flux and flux density term in the core but this term is generally set to zero in making B vs H plots. In getting the value of the magnetizing field H, I assumed a constant H around a intermediate closed path in the core. This is probably not very accurate, also the effects of the magnetic shunts were ignored.
A tentative B vs H plot.
Likes maxwells_demon and Paul Colby
The data was plotted in a B vs H plot and the results are shown in the figure below. The plot suggests that the MOT saturates at around 110V rms. The hysteresis loop indicates that the core is non-linear, which is expected since the MOT core is made of a ferromagnetic material. The shape of the hysteresis loop shows the typical behavior of a ferromagnetic material, with a shallow slope at low field and a steep slope at high field. This suggests that the MOT core is made of a soft ferromagnetic material, which is typical for MOT cores.
The 90v, 100v, 110v and 120v rms data was used to determine the B vs H plot. This was done by taking the time integral of the voltage divided by the number of primary turns and cross sectional area of the core at the primary winding. This gave the flux density B. The magnetizing field H was assumed to be constant around a intermediate closed path in the core. This is probably not very accurate, also the effects of the magnetic shunts were ignored. The plot below shows the estimated B vs H curve for the MOT.
The B vs H plot is difficult to obtain because of the limited resolution of the data. The DI-149 can only measure up to 10 volts, so it is unable to accurately measure the MOT primary voltage at higher applied voltages (120v). Also, the 5000 samples per second for each channel is probably not enough to get accurate readings of the MOT primary current. The B vs H plot was constructed by combining the 90v and 110v data points, and then interpolating the 100v and 120v points.The B vs H plot is not very accurate due to the limited resolution of the data. The DI-149 can only measure up to 10 volts, so it is unable to accurately measure the MOT primary voltage at higher applied voltages (120v). Also, the 5000 samples per second for each channel is probably not enough to get accurate readings of the MOT primary current. If a better data acquisition system with higher resolution is used, a more accurate B vs H plot can be obtained.
Related to Power absorbed and B vs H plot for microwave oven transformer
1. What is the purpose of a microwave oven transformer?
A microwave oven transformer is used to convert the high voltage electricity from a power outlet to a lower voltage that is suitable for powering the magnetron, which is the component that generates the microwaves used for cooking.
2. How does the power absorbed affect the performance of a microwave oven transformer?
The power absorbed by a microwave oven transformer is directly related to its performance. If the power absorbed is too low, the transformer may not be able to provide enough power for the magnetron, resulting in longer cooking times or uneven heating. If the power absorbed is too high, the transformer may overheat and fail.
3. What is the significance of the B vs H plot for a microwave oven transformer?
The B vs H plot, also known as the magnetization curve, shows the relationship between the magnetic field strength (H) and the magnetic flux density (B) in the transformer's core. This plot is important because it helps determine the maximum magnetic flux density that the core can handle before reaching saturation, which can affect the transformer's performance and efficiency.
4. How does the B vs H plot change with varying input voltage for a microwave oven transformer?
The B vs H plot will shift to the left or right depending on the input voltage. A higher input voltage will result in a higher magnetic field strength, causing the plot to shift to the right, and vice versa. This shift can affect the transformer's performance and should be taken into consideration during design and testing.
5. Can the power absorbed and B vs H plot be used to determine the efficiency of a microwave oven transformer?
While the power absorbed and B vs H plot are important factors in determining the efficiency of a microwave oven transformer, they alone cannot accurately determine the transformer's efficiency. Other factors such as the quality of the core material and the winding design also play a significant role in the transformer's efficiency.
  • Electrical Engineering
48K
