Power and Exponential Equations
In summary, the conversation is about understanding how to set up experimental equations for a lab report, specifically for power and exponential forms. The equations given for these forms are y=bx^m and y=be^(mx) respectively. The individual is having trouble understanding how to use these equations and is seeking help. They provide their attempts at solving the equations, but it is pointed out that their first lab report may be incorrect. The conversation ends with the individual stating that they understand now.
beanus
I'm writing a lab report and I'm having trouble understanding how to set up these experimental equations.
I understand Linear (y=mx+b) but my professor wants us to use separate equations to illustrate power and exponential forms.
Power : y=bx^m
Exponential: y=be^(mx)
On the first lab report for the power relationship I had:
Slope of linearization equation (trendline) = 4
Y intercept of linearization equation = .9031
I set up my equation as y=.9031x^4
For the exponential relationship I had:
Slope of linearization equation (trendling) = 1.3029
Y intercept of linearization equation (trendline) = .699
I set up my equation as y=.699e^(1.3029x)
Does anyone know how to use these equations?
Power : y=bx^m
y=.9031x^4
y=.699e^(1.3029x)
Thanks!
Hmm, I am sorry, I don't understand your work here.
Are you using data sets that show linear relationship, making a linear fit to them and using the parameters from that fit to put into a power and exponential equation? That won't work at all.
If you have data sets that show either power or exponential relations then you either use a program to fit that data to the given equation or take the n-th root or logarithm of the y-data and then use linear fitting.
And what do you mean by "how to use these equations"?
Power : y=bx^m
Power : y=bx^m
y=.9031x^4
y=.699e^(1.3029x)
Thanks!
The claim in your first lab report looks wrong. If you say "slope of trendline = 4" (after your word "linearization") you are claiming an equation of the form y = a + 4*x---that is what we mean when we say a linear function with trendline having slope 4. However, if you were looking at *log(y)* vs. *log(x)* and getting a linear form with trendline = 4 (that is, log(y) = c + 4*log(x)), _then_ you would, indeed, have y = a*x^4.
RGV
Thanks I think I got it
As a scientist, it is important to understand the different forms of equations and how they relate to the underlying scientific principles. In this case, the power equation (y=bx^m) represents a relationship where the dependent variable (y) is proportional to some power (m) of the independent variable (x). This means that as x increases, y will increase or decrease at a faster or slower rate depending on the value of m.
On the other hand, the exponential equation (y=be^(mx)) represents a relationship where the dependent variable (y) is proportional to the exponential function of the independent variable (x). This means that as x increases, y will increase or decrease at an exponentially increasing or decreasing rate depending on the value of m.
In your lab report, you have correctly set up the equations for the power and exponential relationships based on the given slope and y-intercept values. It is important to note that the values of m and b will vary depending on the specific data and relationship being studied. It is also important to understand the underlying principles and concepts behind these equations, rather than just memorizing the equations themselves.
One way to better understand these equations is to plot them on a graph and observe how the relationship between x and y changes based on the values of m and b. You can also try plugging in different values for x and observing the corresponding values of y to see how they change.
I hope this helps you better understand and use these equations in your lab reports. Good luck!
FAQ: Power and Exponential Equations
What is a power equation?
A power equation is an equation in which a variable is raised to a specific exponent. For example, y = x^2 is a power equation because the variable x is raised to the exponent of 2.
What is an exponential equation?
An exponential equation is an equation in which a variable is in the exponent. For example, y = 2^x is an exponential equation because the variable x is in the exponent.
What is the difference between a power equation and an exponential equation?
The main difference between a power equation and an exponential equation is the placement of the variable. In a power equation, the variable is raised to a specific exponent, while in an exponential equation, the variable is in the exponent.
How do you solve a power equation?
To solve a power equation, you can use logarithms to isolate the variable. Take the logarithm of both sides of the equation, then use the power rule of logarithms to bring down the exponent and solve for the variable.
How do you solve an exponential equation?
To solve an exponential equation, you can take the logarithm of both sides of the equation and use the power rule of logarithms to bring down the exponent. Then, you can solve for the variable using algebraic techniques.
