POWER - different approach, different results
In summary, "POWER - different approach, different results" emphasizes that adopting varied methodologies in leadership and management can lead to distinct outcomes. It suggests that flexibility in approach, tailored strategies, and innovative thinking are crucial for achieving success and overcoming challenges in various contexts. The piece advocates for embracing diversity in tactics to enhance effectiveness and drive positive change.
Iamconfused123
66
A car with a mass of 1500 kg accelerates at 1.5m/s^2 from rest, and for 12 seconds reaches a velocity of 18m/s. Calculate instantaneous power in the 12th second.
P= W/t, P=Fv, s=1/2at^2
Basically, I tried to find the solution by calculating P=Fs/t, where F= 2250 and s is the distance traveled in the 12th second and that result differs from the result I get when I calculate the power using P=Fv.
##F=ma=1500*1.5=2250N##
##s_{12}-s_{11}= \frac{1}{2}at_{12}^2-\frac{1}{2}at_{11}^2=(0,5*1,5*144)-(0,5*1,5*121)=108-90,75=17.25m##
##P=\frac{Fs}{t}=\frac{2250*17,25}{1}=38812,5W##
##v_{12}=a*t=1,5*12=18##
##P=F*v_{12}=40500W##
Can somebody please tell me where I am wrong? Thank you.
Which is the instantaneous and which is the average power?
You want power averaged over time. This is given by $$\bar P=\frac{\int_0^tP~dt}{\Delta t}=\frac{\int_0^tF~v~~dt}{\Delta t}=\frac{\int_0^t (ma)(at)~dt}{\Delta t}.$$
Power units are Watts, not Newtons.
Likes Iamconfused123
You want power averaged over time. This is given by $$\bar P=\frac{\int_0^tP~dt}{\Delta t}=\frac{\int_0^t (ma)(at)~dt}{\Delta t}.$$
No, I want instantaneous power in 12th second. I didn't solve for average power here, I just typed the entire problem. I know how to solve for average, so that is not important. But I do not know how to solve for instantaneous power. I didn't learn calculus so I don't know what the symbols you wrote that mean.
Yes, Watts, my bad. Thanks.
Edit: I don't know why I typed the entire problem, I edited it.
Like, I do not know calculus, so I can't understand the reasoning behind it. So I am confused, which method shoud I use for instantaneous power P=Fv or P=Fs/t?
You should use P=Fv but note that v ≠ s/t because the car moves under constant acceleration and v = at.
If you don't know calculus, in this case you can use ##\bar P = F\bar v##, i.e. the average power over the time interval is equal to the force times the average velocity over that interval.
Thanks, but can you explain to me why this formula works and the other one does not? But without calculus, just words.
Also, do you recommend I learn calculus first because I am getting really frustrated by having to guess which formula works and which one does not. And if so, up to what level of calculus should I learn 1, 2, 3?
How long would that take? I just covered trigonometry (addition, double and half angles), would I be able to do it without much knowledge of trig? like, I haven't covered grahphs, trig. equations, trig. inequalities, etc.
Homework Statement: ... Calculate average Power and instantaneous power in the 12th second.
There is a mistake in the question which makes it unanswerable.
The 12th second runs from t=11s to t=12s. But the term ‘instantaneous power’ applies to a particular value of t. Without this value the question can't be answered.
I'd guess the intended question is to find the instantaneous power at t=12s (assuming that there is no discontinuity in motion at t=12s, i.e. that the car's acceleration is constant either side of t=12s).
If my guess is correct, you need to find the velocity at t=12s, then you can use P = Fv.
Likes jbriggs444 and Iamconfused123
I assumed that your guess is correct. I read "in the 12th second" to mean "at the 12th second."
yeah, but like, distance at the end of the 12th second or velocity at the end of 12th second, does it matter? if I have the formula for both and both should give back the same result?
PeroK said:
Distance travelled has nothing to do with power.
In my textbook, one formula for power is P=W/t, where W=Fs and "s" is the path on which force is acting up on the object. In this case wouldn't that be the distance crossed? Assuming no friction, drag or losses of energy
The only formula to use for instantaneous power is ##P=Fv## where ##v## is the instantaneous velocity. The equation ##v=s/t## is used when the acceleration is zero and the object covers equal distances in equal times. This is not the case here because the acceleration is not zero which means that the object does not cover equal distances in equal times. The instantaneous velocity is not constant but changes according to ##v=at## which is what you should use instead of ##s/t##. So here ##P=Fv=(ma)(at)=ma^2t## gives the instantaneous power.
Likes Steve4Physics and Iamconfused123
Got it now. Thank you very very much.
Likes kuruman
I deleted that post when I realised it wouldn't help with your confusion over average and instantaneous quantities.
Yes. In case what I said was misconstrued, note that Post #7 was intended only for the OP. I thought that they may have been confused by the poor wording in the question.
It did not relate to anything you had written - apologies if it appeared otherwise.
Likes kuruman
Not to worry. Nothing was misconstrued.
Likes Steve4Physics
That doesn’t help me. At the start of the 12th second or the end?
@Iamconfused123, is the statement in post #1 exactly as given to you? If not, please post the original wording (or maybe it is a translation?)
The intent could be:
  1. at t=12s
  2. at t=11s
  3. the average over the 12th second
Your second attempt correctly solved (1).
Your first attempt found (3).
At ##t = 12~##s substituted in ##P=ma^2t^2##. Is that at the start of the 12th second or the end?
The original statement of the problem (now edited) also asked for the average power which I assumed to be from 0 to 12 s. That wording is lost.
kuruman said:
At t=12 s substituted in P=ma2t2. Is that at the start of the 12th second or the end?
That is not the same as "at the twelfth second". The 12th second lasts from t=11s to t=12s.
Sure. The problem says "A car with a mass of 1500 kg accelerates at 1.5m/s^2 from rest, and for 12 seconds reaches a velocity of 18m/s." To me "for 12 seconds" means that 12 seconds have elapsed and ##t=12~##s in the equation.
But the question is asked in the next sentence. It could have been asked as "at t=11s" without creating any contradiction, so that interpretation is not ruled out.
Please see post #8 for my interpretation of the question asked. OP is from Germany and the formulation of the question may be a translation.
To @Iamconfused123: Can you post the statement of the problem exactly as was given to you?
which, as I wrote in post #16, I can interpret as either t=11s or t=12s.
Now, I do agree that t=12s is the most likely intent. It just is not certain.
  1. at t=12s
  2. at t=11s
It is exactly as posted. Although it is a translation, "in" which I posted refers to the period from 11th to 12th second. We do not have the word "at" in Croatian so it can be confusing sometimes, but if that was the case I would expect the author to write for "at the 12th second" something like "at the end of 11th second".
The author should have been clearer about what she meant.
It can be frustrating, but the collection has 5000 problems for high-school physics, every high school uses it and it's relatively good, so yeah.
@kuruman
Likes Steve4Physics
@kuruman
Perhaps you could find a physics instructor who understands Croatian, show this person the various interpretations mentioned in this thread and ask which one is appropriate to this problem. I think that you now understand the basic physics behind this problem. If you are using it for practice, there is probably nothing more to learn from it except for how to translate Croatian problems into English with minimum loss in translation.
FAQ: POWER - different approach, different results
What is the concept of "POWER - different approach, different results"?
The concept of "POWER - different approach, different results" refers to the idea that by changing the methodology or strategy used to tackle a problem or achieve a goal, one can obtain significantly different and often more effective outcomes. It emphasizes innovation, flexibility, and the willingness to explore unconventional methods.
How can changing approaches impact the results in scientific research?
In scientific research, changing approaches can lead to new discoveries, more efficient processes, and better understanding of phenomena. For example, using a different experimental design, employing new technologies, or applying interdisciplinary methods can provide fresh insights and overcome limitations of traditional approaches.
Can you provide an example of a field where a different approach led to groundbreaking results?
One notable example is the field of medicine, particularly in the development of vaccines. The traditional approach relied on using weakened or inactivated forms of viruses. However, the development of mRNA vaccines, a different approach, led to the rapid creation and deployment of highly effective COVID-19 vaccines, showcasing how innovative methods can yield transformative results.
What are some challenges associated with adopting a different approach?
Adopting a different approach can present challenges such as resistance to change, higher initial costs, and the need for new skills or knowledge. It may also involve risks if the new approach is untested or less understood. Overcoming these challenges requires open-mindedness, investment in training and resources, and a supportive environment for experimentation.
How can organizations foster a culture that encourages different approaches?
Organizations can foster a culture that encourages different approaches by promoting creativity, supporting continuous learning, and valuing diversity of thought. This can be achieved through initiatives like cross-disciplinary collaboration, providing resources for innovation, recognizing and rewarding innovative efforts, and creating an environment where questioning the status quo is welcomed and safe.
