anban
- 20
We are given a circuit as follows: V= 10 V and two resistors are in parallel. R1 is 12 ohms and R2 is 5 ohms. What is the power dissipated in the 12 ohm resistor?
V=IR
P=(I^2)R
I know that the total resistance of the circuit is 3.54 ohms... I found this by solving (1/Rtot) = (1/12)+(1/5) .
The total current of the circuit is 2.82 A, which I found by using V=IR, or 10 = (3.54) I. I will call this current I3.
I will just say that the current going through R1 is named I1 and the current going through R2 is named I2. Using V = IR, I can then say that 10 = (R1*I1) + (R2*I2). I can also say that I1 + I2 = 2.82 A.
I also know that P= V^2 / R. I can deduce that the total power dissipated is (10)^2/3.54, which is 28.2 W.
If the total power dissipated is the sum of each resistor's power dissipation, then 28.2 = (I1^2)(R1) + (I2^2)(R2).
I have a lot of pieces but I still am not sure how to figure out the power dissipated through a single resistor, especially since they have different resistances. Any guidance on where to go next?
