Power dissipated by a Resistor
In summary: It's all about understanding what the components mean.In summary, the power dissipated by the R2=3.0Ω resistor in the figure is not simply the sum of the contributions from each battery. Instead, you must use Kirchhoff's circuit rules to find the actual potential difference across the resistor. This involves creating two loops and considering the contributions from each loop separately.
andquotethat
What power is dissipated by the R2=3.0Ω resistor in the figure if R1=6.0Ω?
Battery 1: 12 V
Battery 2: 15 V
Resistor 1: 3.0 Ω
Resistor 2: 6.0 Ω
P = V2/R
Rtotal = R1 + R2
I started on the left side and used the formula, P = V2/R. I plugged 12 in for V and 3 for R. That resulted in 24 W from the battery on the left. I used the same formula on the right side but plugged in 15 for V and 3 for R. That resulted in 75 W. I added the 2 together and got 99 W.
That was the wrong answer.
I also tried adding 12 and 15 together for V and dividing it by the same R, 3. That gave me 240 W which was also an incorrect answer.
I tried to ratio it as well by taking the left side and 122/9 then taking that result and dividing it by 3. I then did essentially the same to the other side but with 15 for the V and then taking a ratio of that as well. That resulted in 80 W. Once again, the answer was incorrect.
Am I even using the right equation?
To add to the previous reply: You cannot pick a formula and randomly start inserting numbers in it, that will typically never end well. Instead, try to understand what the components are.
In this case, V is the difference in potential across the resistor and R is the resistance of the resistor. You also cannot compute the contributions from each battery separately and add them since your equation is non-linear. You need to find the actual potential difference across the resistor using, eg, what was said in #2.
Thank you both. Most of the other problems I had to do were relatively simple. Understood however. I will step back next time and rethink the problem.
So I would make two loops then? The one on the left going clockwise inside the box and the other going clockwise inside the right box?
Then the current follows both loops but goes from the south to north position in the middle because the volts from the 15 V battery are greater than the volts from the 12 V battery?
Am I right so far?
You would make two loops, yes. Note that each loop will carry an independent current. The current through the middle resistor will be given by the sum of the contributions from each loop (taken with the appropriate sign!).
Noted. I did finally figure out how to get the right answer. Thank you all for your help and I'll remember not to plug and chug next time.
Related to Power dissipated by a Resistor
What is power dissipation?
Power dissipation refers to the process of converting electrical energy into heat energy. In the context of a resistor, it is the amount of heat generated when an electric current flows through it.
How is power dissipation calculated?
The power dissipated by a resistor can be calculated using the formula P = I^2 * R, where P is power (in watts), I is current (in amperes), and R is resistance (in ohms).
What factors affect the power dissipation of a resistor?
The power dissipation of a resistor is affected by its resistance, current flowing through it, and the environment it is operating in. Higher resistance or current will result in higher power dissipation, and ambient temperature can also impact the amount of heat generated.
Why is power dissipation important to consider in electronic circuits?
Power dissipation is important to consider in electronic circuits because it can affect the performance and reliability of components. Excessive heat generated by power dissipation can lead to component failure, and it can also impact the efficiency and overall functionality of the circuit.
How can power dissipation be managed in electronic circuits?
Power dissipation can be managed in electronic circuits by using resistors with higher power ratings, spreading out heat-generating components, and implementing cooling mechanisms such as heat sinks or fans. Calculating and monitoring power dissipation is also important in designing and optimizing electronic circuits.
