Power Input for Motor and Back EMF
In summary, when a motor is rotating at high speed, the back emf reduces the current and therefore reduces the power required. Additionally, the power drawn by a motor is minimum at high speed and maximum when stalled. When the motor is unloaded, it spins at maximum rpm and draws little current, resulting in no power output. However, as the motor is loaded, it spins slower, draws more current, and outputs more power. The motor's efficiency can be seen in the torque, current, rpm, and power output curves.
psycho
Hello everyone, I'm a bit confused about the power drawn by a motor. Since back emf reduces current when the motor is rotating at high speed, is it true that back emf reduces the power required at high speed? THX :D
Hi psycho. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
Yes. At the higher speed back emf is greater, so current reduces. Of course, you'll only see such high range speeds when the motor is unloaded, or very lightly loaded, so it isn't being required to produce much mechanical power (compared to its full capabilitiy) under those conditions, anyway.
Hello nascent, how about the power drawn by the motor? Is it Also minimum at highspeed and maximum when stall?
If you operate your DC motor from a fixed voltage, then the motor draws maximum electrical power when stalled. Note, that when stalled the motor is delivering zero mechanical power to its shaft, ω=0.
Google dc motor efficiency curves and look at torque, current, rpm and power output (efficiency) curves.
When a motor is unloaded it spins at maximum rpm and draws little current and outputs no power. As you load it down it spins slower, draws more current and outputs more power. If the motor were 100% efficient, the Voltage X Current drawn would equal the output power. As the motor slows down due to load, the back emf reduces so the current (and output power) increases.
Related to Power Input for Motor and Back EMF
1. What is the relationship between power input and back EMF in a motor?
The power input for a motor is the amount of electrical energy that is supplied to the motor. Back EMF, also known as counter electromotive force, is the voltage generated by the motor as it rotates. The two are directly related, as an increase in power input will result in an increase in back EMF.
2. How does the power input affect the speed of a motor?
The power input for a motor directly affects its speed. The higher the power input, the faster the motor will rotate. This is because the power input determines the amount of energy available to overcome the resistance and friction in the motor, allowing it to rotate at a faster speed.
3. Can the power input and back EMF be controlled?
Yes, the power input and back EMF can be controlled through various methods such as changing the supply voltage, adjusting the motor's load, or using speed controllers. By controlling the power input and back EMF, the speed and torque of the motor can also be controlled.
4. What is the significance of back EMF in motor design?
Back EMF is an important factor to consider in motor design as it affects the motor's efficiency and performance. A high back EMF can reduce the amount of current flowing through the motor, resulting in lower power consumption and increased motor life. However, too much back EMF can also cause issues such as motor overheating and loss of torque.
5. How does the power input and back EMF impact the overall efficiency of a motor?
The power input and back EMF both play a significant role in the overall efficiency of a motor. A well-designed motor will have a balance between the power input and back EMF to ensure optimal performance and efficiency. Too much power input can lead to energy wastage, while too much back EMF can cause the motor to work harder and decrease its efficiency.
  • Electrical Engineering
