Power of a car, time distance speed mass
In summary: When you do that, you get the desired answer.In summary, the car with a mass of 1 metric ton reaches a speed of 20 m/s in 5 seconds. The power of the car is 40 kW. This can be calculated using the equation P = A/t, where A is the work done and t is the time taken. The average power is used to calculate the answer, instead of the instantaneous power.
abruski
A car with mass m = 1 metric ton (1000 kg) in time t = 5 seconds reaches speed v = 20 m/s
What is the power of the car? P = ? kW (kilo Watts)
F - force, a - acceleration, A - work, s - distance
[tex]P = \frac{A}{t}[/tex]
[tex]P = Fv[/tex]
[tex]F = ma[/tex]
[tex]a = \frac{v}{t}[/tex]
[tex]A = Fs[/tex]
[tex]s = vt[/tex]
The answer given in the book is 40 kW but I get 80 kW. With the 40 kW I get that the acceleration s 2 m/s[tex]^{2}[/tex], which means that
[tex]\frac{v}{t} = \frac{20}{5} = 2[/tex]
Maybe I miss something. Any help is appreciated.
Show how you got your answer. Hint: Find the average power.
[tex]a = \frac{v}{t} = \frac{20}{5} = 4 \frac{m}{s^{2}}[/tex]
[tex]s = vt = 100 m[/tex]
[tex]F = ma = 1000*4 = 4000 N[/tex]
[tex]A = Fs = 4000*100 = 400000 J[/tex]
[tex]P = Fv = 4000*20 = 80 000 W[/tex]
[tex]P = \frac{A}{t} = \frac{400000}{5} = 80 000 W [/tex]
seems pretty straightforward to me
40 kW is a correct answer.
Distance is not 100 m.
While the final answer should be identical no matter how you solve the question, comparing final energy of the car with the work done seems to be much easier approach.
how come distance is not 100m?
20 m/s is a FINAL speed, not average.
What about the acceleration?
What about it? Realize that the instantaneous power varies throughout the motion. You want the average power. Rather than mess around with kinematics, use the most basic definition of power as energy/time.
Related to Power of a car, time distance speed mass
1. What is the relationship between the power of a car and its speed?
The power of a car is directly proportional to its speed. This means that as the power of a car increases, its speed also increases. This is because power is the rate at which work is done, and in the case of a car, work is measured by the distance it travels over a certain period of time. Therefore, a higher power output means the car can cover more distance in a shorter amount of time, resulting in a higher speed.
2. How does the time taken to travel a certain distance affect the power of a car?
The time taken to travel a certain distance does not directly affect the power of a car. The power of a car depends on its engine and other factors such as aerodynamics, weight, and road conditions. However, the time taken to travel a certain distance can indirectly affect the power of a car by influencing its speed. A shorter time taken to cover a distance means a higher speed, which requires more power.
3. How does the mass of a car impact its power?
The mass of a car plays a significant role in determining its power. A heavier car requires more power to accelerate and maintain a certain speed compared to a lighter car. This is because more power is needed to overcome the inertia of a heavier car. Therefore, a car with a higher mass will typically have a higher power output in order to achieve the same speed as a lighter car.
4. What is the relationship between speed and distance?
The distance traveled by a car is directly proportional to its speed. This means that as the speed of a car increases, the distance it covers in a certain amount of time also increases. For example, if a car is traveling at a speed of 60 miles per hour, it will cover a distance of 60 miles in one hour. Similarly, if the speed is doubled to 120 miles per hour, the distance covered in one hour will also double to 120 miles.
5. Does the power of a car affect its braking distance?
Yes, the power of a car can affect its braking distance. A car with a higher power output will have a shorter braking distance compared to a car with a lower power output. This is because a higher power output allows the car to accelerate and decelerate faster, resulting in a shorter stopping distance. Additionally, other factors such as the weight and condition of the brakes also play a role in a car's braking distance.
