Power of Complex numbers proof
In summary, the homework statement is trying to solve for z = 1 + cos x + i*sen x, but ends up with z = 1 + cos x - i*sen x because the exponent is wrong on the right side. The problem is that if x = 2 then \varphi = x/2, but this is not what is desired. The solution is to use the Euler form for complex numbers and prove that \varphi = x/2.
libelec
176
Prove that [tex]\left( {\frac{{1 + \cos x + i\sin x}}{{1 + \cos x - i\sin x}}} \right)^n} = \cos nx + i\sin nx[/tex]
I thought it would be a good idea calling z = 1 + cos x + i*sen x, because then 1 + cos x - i*sen x would be [tex]\bar{z}[/tex], and then I would have something of the form [tex]{\left( {\frac{z}{{\bar z}}} \right)^n} = {\left( {\frac{{{z^2}}}{{{{\left| z \right|}^2}}}} \right)^n}[/tex]. If I use the Euler form for complex numbers, being [tex]\varphi[/tex] the argument of z, then z[tex]\left| z \right|{e^{i\phi }}[/tex].
So [tex]{\left( {\frac{{{z^2}}}{{{{\left| z \right|}^2}}}} \right)^n} = {\left( {\frac{{{{(\left| z \right|{e^{i\phi }})}^2}}}{{{{\left| z \right|}^2}}}} \right)^n} = {\left( {\frac{{{{\left| z \right|}^2}{e^{i2\phi }}}}{{{{\left| z \right|}^2}}}} \right)^n} = {\left( {{e^{i2\phi }}} \right)^n} = {e^{i2n\phi }}\
[/tex]. Which would all work just fine with the proof if I could somehow prove that [tex]\varphi[/tex] = x/2.
My question is, is this OK? And if it is OK, how can I prove that [tex]\varphi[/tex] = x/2?
Thanks
Aren't the numerator and denominator equal to 1 + eix and 1 + e-ix respectively? That's the direction I would go. And the right side is ei*nx = (ei x)n = (cos x + i sin x)n,
One comment about your work: You have the exponent wrong on the right side. Your equation should be as follows:
[tex]{\left( {\frac{z}{{\bar z}}} \right)^n} = {\left( {\frac{{{z^2}}}{{{{\left| z \right|}^2}}}} \right)^{n/2}}[/tex]
That doesn't look right...
Yes, that's basically what I did. Only that I recalled the whole numerator z so that I could deal with the division.
No, why? [tex]\frac{z}{{\bar z}} = \frac{{{z^2}}}{{{{\left| z \right|}^2}}}[/tex]
[tex]{\left( {\frac{z}{{\bar z}}} \right)^n} = {\left( {\frac{{{z^2}}}{{{{}^2}}}} \right)^{n/2}}[/tex]
It is not right. Try, e.g., n=2 for z=(cos x + i sin x)n and we have
(cos x + i sin x)2= [tex](cos^2x-sin^2x) + i(2cosxsinx)[/tex], but
[tex]\left| z \right|^2 = \left| cos x + isinx \right|^2=1[/tex]
[quote Originally posted by Mark44]
[tex]{\left( {\frac{z}{{\bar z}}} \right)^n} = {\left( {\frac{{{z^2}}}{{{{|z|}^2}}}} \right)^{n/2}}[/tex]
[/quote]
I agree. I didn't notice that the conjugate in the denominator on the left had changed to the square of the magnitude in the expression on the right.
Back to the original problem...
[tex]Prove~that~\left( {\frac{{1 + \cos x + i\sin x}}{{1 + \cos x - i\sin x}}} \right)^n} = \cos nx + i\sin nx[/tex]
[tex]\left( {\frac{{1 + \cos x + i\sin x}}{{1 + \cos x - i\sin x}}} \right)^n} = \left(\frac{1 + e^{ix}}{1 + e^{-ix}}\right)^n[/tex]
Inside the parentheses, multiply numerator and denominator by eix. Then factor eix out of the two terms in the numerator and cancel the factor that is common to numerator and denominator. It's then easy to show that what you have left equals cos(nx) + isin(nx) = einx = (eix)n.
EDIT: I hadn't seen that comment from Mark44.
Thanks, I wouldn't have thought that.
Edit.
FAQ: Power of Complex numbers proof
What is the power of complex numbers?
The power of complex numbers refers to the ability to raise a complex number to a certain exponent. This is similar to raising a real number to an exponent, but in this case, the exponent can be a complex number as well.
What is the proof of the power of complex numbers?
The proof of the power of complex numbers involves using the polar form of complex numbers and De Moivre's theorem. This theorem states that for any complex number z with a polar form of r(cosθ + isinθ), raising it to the nth power results in rn(cos(nθ) + isin(nθ)).
What are the benefits of using complex numbers in power calculations?
Using complex numbers allows for a more efficient and compact representation of power calculations. It also enables the use of De Moivre's theorem, which simplifies the calculation process.
Can complex numbers be raised to any power?
Yes, complex numbers can be raised to any power, including negative and fractional powers. This is because the polar form of complex numbers allows for the use of any real number as an exponent.
How is the power of complex numbers used in real-world applications?
The power of complex numbers has many applications in various fields such as engineering, physics, and computer science. It is used in signal processing, electrical circuit analysis, and even in quantum mechanics. It also has practical applications in calculating electric currents, predicting weather patterns, and analyzing sound waves, among others.
