Power Output Given Certain Torque
In summary, the conversation discusses the problem of determining the power output of a motor given a certain amount of torque. The participants mention the need for rotational velocity and resistance in order to calculate power, but are unsure of how to find these values. They suggest estimating the rotational speed based on a person's ability to rotate a 5m radius circle and using gears to adjust the rotation speed. The conversation also mentions the importance of considering the electrical load attached to the motor and how it affects the output power. The person seeking help ultimately wants to understand the relationship between force and power output in a motor.
Jmeeks29ig
Hi,
I have a problem that I've been trying to figure out for a while but cannot seem to get on my own. I'm trying to figure out how much power will be generated in a motor given a certain amount of torque. The problem is, to find the amount of power output , I also need to know the rotational velocity, which I cannot seem to find. I don't know how much resistance the motor would give.
Here's a simple example:
A man rotates a shaft of radius 5 m, with a constant force of 10 N, on a dc motor. How much power does the motor output?
I know that the rotational velocity is missing, as well as the number of turns in the motor, but I don't know how much it would be without knowing the specifications of the motor. If you could steer me in the right direction and maybe give me similar examples, it would be much appreciated, thanks!
Also, how would I know how much resistance the motor provides, in Newtons?
As Power = Torque × Rotational speed, you need to know more.
As you seem to understand, without the rpm you simply cannot know. However, assuming that as the man applies 10 N (which would be 50 Nm of torque) the shaft does not accelerate then that means that the resistance is also 10 N (50 Nm). If it wasn't, then the shaft would accelerate until the forces balance out, until the man can't keep up, or until something gets destroyed.
Your best bet with the information given is to estimate how fast a person can get around a 5m radius circle.
Likes Nidum
The rotational speed is going to be impossibly slow for a directly driven dynamo but let's work it out anyway for curiosity :
4 minute mile : 15 mph or 6.7 M/sec
Walking speed : 3 to 5 mph or 1.35 to 2.25 M/Sec
Choose a spot value - say 2 M/sec
Circumference of circle = 10 Pi = 31.42 M .
Revs/sec = 2 / 31.42 = 0.064 rev/sec or 3.8 rpm .
Likes russ_watters
You boys have beaten me to it - fortunately, as I'm much more long-winded!
Anyhow, when I got to working out rotational speed, I thought maybe that's not important. 10N at 2m/s is 20W mechanical input power to the dynamo and use whatever gears you need to make that a sensible rotation speed.
The suggestion I would make to OP is, stop thinking of it as a motor and just Google dynamo or DC generator and find endless pages of explanation at all levels
But I hate these cryptic questions: they intrigue me, but frustrate me. I just hope he tells us what it is he really wants to know.
Likes russ_watters
Sorry it took so long to get back, but thanks so much for the explanations! That helps me to understand it better. As for the cryptic question, I'm sorry, but I don't know if I'll be able to get much more specific. I want to be able to understand how much power output I will get if I can be applying a constant force to a motor, but it makes it hard when I don't know how fast that shaft will rotate due to the force I place on it. However, it does seem a little bit clearer now!
Glad you came back. Sorry I was so tetchy about it!
This is one point that hasn't really come up yet, unless I missed it before. If you try to rotate a dynamo, the resistance depends on the electrical load attached. A dynamo unconnected is easy to rotate - you are only overcoming friction and magnetic losses. Once a load is connected and current flows, that creates another force (torque), usually the dominant one, opposing the rotation. (If the loss force is large, compared to the load force, then the generator is not efficient. http://windstreampower.com/wordpress/wp-content/uploads/2013/01/EFFICIENCY.pdf suggests 85% is average for PMDC generator.)
Jmeeks29ig said:
... I don't know how fast that shaft will rotate due to the force I place on it. ...
"How fast the shaft will rotate" is not a simple question (without more info) because it is determined by a balance between several variables. If the shaft turns faster, the output emf increases, so the current through the load probably increases, which increases the opposing torque and may tend to slow the shaft. That's the output side. On the input side, you say the man pushes with 10N. Being intelligent he can monitor that and try to keep it constant as the shaft speed varies, but there will be a limit, if it goes too fast and he can't keep up, when that force will fall. Or he may try to keep the speed constant by pushing harder if it slows and less if it speeds up. Again there must be a limit to how hard he can push.
You see, so much depends on what your real problem is. I find it hard to believe that someone is walking round in a 5m radius circle pushing a long arm with only 10N force, so I assume that is just some random numbers you made up to help us. If we knew what you really wanted to know (or maybe, why you want to know) there's more chance we can say something useful.
As others have said, that simply is not an answerable question. Power out depends on power in. Force is not power.
So what I'm asking is, why do you say "constant force"? Where does this constant force come from? Maybe if we know more about it, we can work out what power you have available, then we'd be getting somewhere.
Related to Power Output Given Certain Torque
1. What is "power output given certain torque"?
Power output given certain torque is a measurement of the amount of work that can be done by a machine or engine. It is determined by the amount of torque (rotational force) that is applied to a machine and the speed at which it is applied.
2. How is power output calculated?
Power output is calculated by multiplying the amount of torque applied to a machine by the rotational speed at which it is applied. This can be expressed as the formula P = T x ω, where P is power, T is torque, and ω is rotational speed measured in radians per second.
3. Can power output and torque be adjusted independently?
Yes, power output and torque can be adjusted independently. By changing the amount of torque applied to a machine or by altering the rotational speed at which it is applied, the power output can be adjusted accordingly.
4. What are the units of measurement for power output and torque?
Power output is typically measured in watts (W) or horsepower (hp), while torque is measured in newton-meters (Nm) or foot-pounds (ft-lb).
5. What factors affect power output given certain torque?
The main factors that affect power output given certain torque include the design and efficiency of the machine or engine, the type of fuel or energy source used, and any external forces or resistances that may be acting on the machine.
  • Mechanics
  • Mechanics
  • Mechanics
  • Mechanics
