Power Radiated From a Copper Cube
The discussion revolves around calculating the power radiated from a copper cube using the Stefan-Boltzmann law. The initial calculations, using an emissivity of 1, a surface area based on a 1 cm edge length, and a temperature of 340°C, yield a radiated power of approximately 4.8 W. However, the provided answer key states the correct answer is 19 W, which corresponds to a cube with a 2 cm edge length. Participants suggest verifying the problem parameters with the instructor, as the initial calculations appear accurate for the given dimensions. The discrepancy highlights the importance of confirming problem details in physics assignments.
Randomized10
What power is radiated from a 340°C copper cube 1.0cm on a side? Assume an emissivity of 1
A. 0.76 W
B. 1.8 W
C. 3.4 W
D. 8.0 W
E. 19 W
$$\frac{dQ}{dt}=e\sigma AT^4$$
##e## is emissivity
##\sigma## is the Stefan-Boltzmann constant, ##5.67*10^{-8} W m^{-2} K^{-4}##
A is the surface area
T is the temperature
##\frac{dQ}{dt}## is the rate of heat transfer or radiated power
At first glance this appeared to be an easy problem, just plug in the values and go, so that's what I did. ##e=1##, ##\sigma=5.67*10^{-8} Wm^{-2}K^{-4}##, ##A=6*(1cm)^2=6*(0.01m)^2=6*0.0001m^2=0.0006m^2=6*10^{-4}m^2##, and ##T=340^{\circ}C=613.15K##. After plugging in the values I got ##\frac{dQ}{dt}=1*5.67*10^{-8}*6*10^{-4}*613.15^4=3.402*10^{-11}*1.4134*10^{11}=4.808W##, but that isn't one of the possible answers no matter how you round it. The answer key says that the correct answer is 19 W, but I don't know how to get there. I tried working out the math using Celsius instead of Kelvin, and got ##\frac{dQ}{dt}=0.4546W##, which isn't right either. Any insights as to what I'm doing wrong would be appreciated.
My calculation agrees with yours. This is not the first time that the correct solution does not match any of the offered answers. I suggest that you show your answer to the person who assigned you this problem because he/she/ze/they needs to know.
Likes Randomized10
I agree with @kuruman. Your answer of 4.8 W looks correct. The answer of 19 W corresponds to an edge length of 2.0 cm.
Likes Randomized10
Ok, I'll talk to the professor. Thank you!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
