Power required to drive up a hill
In summary, we discussed a 1200kg car traveling at a constant velocity of 90km/h on a road, and then starting to climb a 30 degree hill. To maintain the constant velocity, we determined that the additional power required from the engine would be 147kW. There were some discussions about the slope of the hill, with different definitions using either sine or tangent. However, the standard way to describe a hill on British road signs is "1 in N", where N refers to the hypotenuse.
anthonyk2013
125
Forum guidelines require the use of the homework template. This thread has not been deleted due to already having relevant answers.
Consider a 1200kg car cruising steadily on a road at 90km/h. Now the car starts to climb a hill that is sloped a 30 deg from horizontal . If the velocity of the car is to remain constant during climbing, determine the additional power required that must be delivered by the engine.
KE=mv2/2
velocity=9/3.6=2.5m/s
KE= 1200*2.52/2=3750 J
No sure where to go from here.
Please use the template as was asked from you before. [edit] my mistake, but nevertheless.
In that post you can find all you need, so there's no reason to be unsure.
Look at the rate of change of the total energy and ask yourself where that has to come from.
Assume the hill to be frictionless because we have no information about the coefficient of friction. So the force the car has to exert to go up the hill at constant velocity must be equal to 1200g( from Newtons second law, because you don't want rhe car to acceleeate) .Using this value , you can calculate the work done by the car, and then the work done per second, because you know the velocity
PE=m*g*h h=cos30deg
The difference is the (additional) power required to overcome the gravity force added by the incline ( m * g * sine ( 30 ° ) )
That's some real steep road. 58% :))
:D:L
PE=1200*9.81*(sin 30)=5886 J
Not really, Borek. Only 50% :)
No. Wrong dimension.
In fact, the earlier h=cos30deg had the same problem.
Where?
1200 is kg, g is m/s2. Joules is kg m2/s2.
YA stupid of me.
This is going to be a long thread if we don't make some headway. Power is energy per time. Energy is force times length, so Power is force times length/time. All the ingredients are at hand now, so what's the answer (preferably in an expression, the numbers aren't all that interesting)
Power= m*g*(sin30)*v
P=1200*9.81*(0.50)*2.5=14715w, 147kw
Almost. Another remnant (from the first post, this one! Don't write 9/3.6, instead: ) v = 90000 m / 3600 sec = 25 m/s. So the 14715 becomes 147150 and that is 147 kW
There are two, slightly different definitions - one uses sinus, the other tangent. One yields 50%, the other 58%. My understanding is that the one based on tangent is more commonly used.
Whichever we use - still steep :)
The only one I've ever seen used for the slope of a road is "rise/run", or tangent.
Not so easy to determine which one is used for the slope.
Sine has the advantage it's useful: odometer tells you how far you've climbed
But I see a lot of "definitions" use the tangent, indeed. So slopes can be well over 100%, up to infinity !
The standard way to describe a hill on British road signs is "1 in N", where N refers to the hypotenuse, so N would be the cosec. I believe it is also used for railways.
Related to Power required to drive up a hill
What is "power required to drive up a hill"?
"Power required to drive up a hill" refers to the amount of energy or force needed to move a vehicle or object up a hill. It takes into account factors such as the weight of the vehicle, the steepness of the hill, and any resistance or friction that may be present.
How is the power required to drive up a hill calculated?
The power required to drive up a hill is calculated by multiplying the force needed to move the vehicle up the hill by the velocity at which it is moving. This can be calculated using the equation Power = Force x Velocity.
What factors affect the power required to drive up a hill?
The power required to drive up a hill is affected by several factors, including the weight of the vehicle, the incline of the hill, the speed of the vehicle, and any resistance or friction present. Additionally, factors such as the type of terrain and the condition of the vehicle's engine can also impact the power required.
How does the power required to drive up a hill differ from driving on flat ground?
The power required to drive up a hill is typically greater than the power required to drive on flat ground. This is because the vehicle must work against the force of gravity to move up the hill, which requires more energy. Additionally, the increased incline and potential for resistance or friction on a hill can also contribute to the higher power requirement.
Can the power required to drive up a hill be reduced?
Yes, the power required to drive up a hill can be reduced by decreasing the vehicle's weight, increasing its speed, or reducing any resistance or friction. Additionally, using a vehicle with a more powerful engine or one specifically designed for driving on hills can also help reduce the power required.
