Power Series Converge Absolutely
The series \(\sum^{∞}_{n=1} \frac{4^n * x^n}{n!}\) converges absolutely for all values of \(x\) based on the Ratio Test. The calculation shows that the limit approaches zero, indicating no restrictions on \(x\). It is emphasized that when applying the Ratio Test, one should use the absolute values of the terms. The result of \(4|x| \cdot \lim_{n \to \infty} \frac{1}{n+1} = 0\) confirms this conclusion. Therefore, the series converges for \(-\infty < x < \infty\).
whatlifeforme
for what values of x does the series converge absolutely?
\displaystyle \sum^{∞}_{n=1} \frac{4^n * x^n}{n!}
Ratio Test
\displaystyle \frac{4^{n+1} * x^{n+1}}{n+1)!} * \frac{n!}{4^n * x^n}
4x * limit (n->inf) \displaystyle \frac{1}{n+1} = 0
What do I do now since the limit is zero? I asked a similar question in another thread, but the limit turned out to be 1. I am sure that this limit is zero.
What was your purpose in calculating that? How is that number, whether it is 0 or 1 or whatever, tell you about the "radius of convergence"?
Ratio Test
It means that the series converges for all values of x.
BTW, when you use the Ratio Test, you should be working with the absolute values of the terms in your series.
This is the ratio you should be working with:
$$ \frac{4^{n+1} * |x|^{n+1}}{(n+1)!} * \frac{n!}{4^n * |x|^n}$$
The result you get will be 4|x| ## \lim_{n \to \infty} 1/(n + 1)## = 0, which places no limits on the values of x.
do i leave the answer at 4|x| limn→∞1/(n+1) = 0 and put -inf < x < inf. or do i need to prove this somehow?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
