Power Series Odd Function Proof
In summary, for a function to be odd, the sum of its odd terms must equal zero. Therefore, if f(x) is an odd function with a series expansion of an x^n for n = 0 to infinity, then all even terms, such as a0, a2, a4, etc., must be equal to zero. This is because the nth derivative of an odd function always produces an even function, and when evaluated at 0, the result is always 0.
harrietstowe
46
Suppose that f(x)= summation an x^n for n = 0 to infinity for all x. If f is an odd function, show that a0 = a2 = a4 = ... = 0.
I said to consider sin(x), an odd function. When you do a series expansion only odd terms exist in the series so all even terms are equal to zero. This is because the nth derivative of sin(x) where n is an even number >= 2 always produces some form of cos(x) and when you plug 0 into cos(x) you get 0 and so even terms disappear. I was told that I restated the question and that I need to think harder about odd functions. I don't know how else to answer this. Thanks
That's one EXAMPLE. It doesn't prove it's true for all such functions.
Suppose you have a function for which a0≠0, or a2≠0, or a4≠0, ...
Show that such a function is NOT odd.
What's true if a function is odd?
What's true if a function is NOT odd?
If f(x) is odd then f(0)=0, right? Now do you know that if f(x) is odd then f'(x) is even? And vice versa? Now what about f''(x)? What about the nth derivative of f(x)?
For odd functions, [itex] f(-x) + f(x) = 0 [/itex]. Using that will tell you [itex] a_0 + a_2 x^2 + a_4 x^4 \cdots = 0 [/itex].
FAQ: Power Series Odd Function Proof
What is a power series?
A power series is an infinite series of the form ∑n=0∞ an(x-c)n, where an are coefficients, x is a variable, and c is a constant.
What is an odd function?
An odd function is a function f(x) such that f(-x) = -f(x) for all x. This means that the graph of an odd function is symmetrical with respect to the origin.
How can we prove that a power series is an odd function?
To prove that a power series is an odd function, we can use the properties of odd functions and the properties of power series. Specifically, we can show that the coefficients of the odd powers of x are all equal to 0, and the coefficients of the even powers of x are all equal to 0.
What is the importance of proving that a power series is an odd function?
Proving that a power series is an odd function can help us in solving problems involving symmetry, finding points of inflection, and determining the behavior of a function near the origin. It also allows us to simplify calculations and make predictions about the function's behavior.
Are all power series odd functions?
No, not all power series are odd functions. In order for a power series to be an odd function, the coefficients of the odd powers of x must be equal to 0, and the coefficients of the even powers of x must be equal to 0. If these conditions are not met, the power series will not be an odd function.
