Power series, radius of convergence and Abel's Theorem
In summary, the statement is true for R \in \mathbb{R}-\{0,\pm \infty\} and follows from Abel's theorem and the continuity of x^n on \mathbb{R}. For the case R = \pm \infty, the statement holds true for any x' > 0 as x' is an interior point in the interval of convergence and the series converges uniformly for x'.
fmam3
82
Suppose the series [tex]\sum_{n=0}^{\infty} a_n x^n[/tex] has radius of convergence [tex]R[/tex] and converges at [tex]x = R[/tex]. Prove that [tex]\lim_{x \to R^{-}}\large( \sum_{n = 0}^{\infty} a_n x^n \large) = \sum_{n = 0}^{\infty} \large( \lim_{x \to R^{-}} a_n x^n \large) [/tex]
2. Question
For the case [tex]R \in \mathbb{R}-\{0\}[/tex] (i.e. the radius of convergence is a finite nonzero real number), then the above is a straight forward application of Abel's Theorem on the LHS, and an easy application of the fact that [tex]x^n[/tex] is a continuous function on [tex]\mathbb{R}[/tex] on the RHS. If [tex]R = 0[/tex], then the result is trivial.
However, my question is how do you (or do you even) deal with the case [tex]R = \pm \infty[/tex]? That is, do we even say that the power series converges at [tex]x = R = \pm \infty[/tex]?
Thanks in advance!
No. [tex] \pm \infty [/tex] isn't a real number.
Say x = x' is an interior point in the interval of convergence (we can assume x' is positive without any loss of generality), then the series converges uniformly for x' and the theorem you proved follows trivially from Abel's theorem. But if [tex] R = \infty [/tex] then you can always find a value x'' > x' so that x' is an interior point in the interval [0, x''] and so the series converges uniformly for x' and so your theorem follows again for x'.
Related to Power series, radius of convergence and Abel's Theorem
1. What is a power series?
A power series is an infinite series of the form ∑n=0 cn(x-a)n, where cn are constants and a is the center of the series. It is a function that can be represented as a sum of monomials, or terms, where the exponent of each term increases by 1.
2. How is the radius of convergence determined?
The radius of convergence of a power series is determined by using the ratio test. The ratio test states that if the limit of |cn+1/cn| as n approaches ∞ is less than 1, the power series will converge. The radius of convergence is then equal to the absolute value of this limit.
3. What is the significance of the radius of convergence?
The radius of convergence determines the values of x for which the power series will converge. If |x-a| is less than the radius of convergence, the series will converge. If |x-a| is greater than the radius of convergence, the series will diverge. The radius of convergence also tells us how quickly the series will converge or diverge.
4. What is Abel's Theorem?
Abel's Theorem, also known as Abel's Limit Theorem, states that if a power series converges at some point x=a, it will also converge for all points on the interval (-R, R) where R is the radius of convergence. This theorem is useful in determining the values for which a power series will converge.
5. How is Abel's Theorem used in applications?
Abel's Theorem is used in many areas of mathematics and science, including physics, engineering, and economics. It is used to approximate functions, solve differential equations, and study the behavior of series and integrals. It is also used in the study of complex numbers and their properties.
