Power series solution for Log(1+x)
In summary, the given conversation discusses different methods of proving the equation $\log(1+x)=x-\frac{x^2}{2}+\frac{x^3}{3}+\cdots$ and concludes that it can be proven by using the Maclaurin series expansion of $1/(1+x)$. This simplifies the proof as it shows the two expressions have the same derivative, making the constant term in the Maclaurin series equal to zero. This is a unique case that is worth noting.
ssh
Show that,
\[\log(1+x)=x-\frac{x^2}{2}+\frac{x^3}{3}+\cdots\]
Mathematics news on Phys.org
ssh said:
Show that log(1+x) = x - x2\2 + x3​\3...
Use that $\dfrac{1}{1+x}=1-x+x^2-x^3+\ldots\quad (|x|<1)$ and take into account that all power series can be integrated term by term on an interval lying inside the interval of convergence.
Can we write this as a Taylor's series as f(x) = Log(1+x), then f'(x)=1\1+x so on.
Of course you can. But using that method you only obtain the Taylor series of $f(x)=\log (1+x)$, that is $\displaystyle\sum_{n=1}^{\infty}(-1)^{n-1}\dfrac{x^n}{n}$. To prove that $\log (1+x)=\displaystyle\sum_{n=1}^{\infty}(-1)^{n-1}\dfrac{x^n}{n}$ in $(-1,1)$ (also in $x=1$) you need to verify that the remainder of the Taylor series converges to $0$.
ssh said:
Show that,
If you want to use the long method, remember that a Maclaurin series for a function is given by $\displaystyle \begin{align*} f(x) = \sum_{n = 0}^{\infty} \frac{f^{(n)}(0)}{n!}x^n \end{align*}$
So evaluating the derivatives gives
$\displaystyle \begin{align*} f(x) &= \ln{(1 + x)} \\ f(0) &= 0 \\ f'(x) &= \frac{1}{1 + x} \\ f'(0) &= 1 \\ f''(x) &= -\frac{1}{(1 + x)^2} \\ f''(0) &= -1 \\ f'''(x) &= \frac{2}{(1 +x)^3} \\ f'''(0) &= 2 \\ f^{(4)}(x) &= -\frac{3!}{(1 + x)^4} \\ f^{(4)}(0) &= -3! \\ f^{(5)}(x) &= \frac{4!}{(1 + x)^5} \\ f^{(5)}(0) &= 4! \\ \vdots \end{align*}$
So substituting these in gives
$\displaystyle \begin{align*} \ln{(1 + x)} &= \frac{0}{0!}x^0 + \frac{1}{1!}x^1 + \frac{(-1)}{2!}x^2 + \frac{2}{3!}x^3 - \frac{3!}{4!}x^4 + \frac{4!}{5!}x^5 - \dots + \dots \\ &= x - \frac{x^2}{2} + \frac{x^3}{3} - \frac{x^4}{4} + \frac{x^5}{5} - \dots + \dots \end{align*}$
Now, we have to prove the Taylor's remainder [tex]R_n(x)[/tex]:
$$R_n(x)=\dfrac{f^{(n+1)}(\xi)}{(n+1)!}x^n=\dfrac{(-1)^n}{(1+\xi)^{n+1}}\dfrac{x^{n+1}}{(n+1)!}\quad (\xi \mbox{ between }0\mbox{ and }x)$$
has limit [tex]0[/tex] for [tex]x\in (-1,1)[/tex] as [tex]n\to \infty[/tex]. For that reason is better to use the series expansion of [tex]1/(1+x)[/tex].
Taking the derivative of the MacLaurin series gives you
$1 -x +x^2 - x^3 + x^4 + \ldots$
Since this is a geometric series with ratio $-x$, it equals $\frac{1}{1 + x}$ when x is in $(-1, 1)$.
This shows the expression $\ln(1+x)$ and its MacLaurin expansion to have the same derivative over $(-1, 1)$, which means they are equal within a constant. And, since they are equal at $x=0$, this constant is zero.
If my reasoning is correct, this is simpler than proving the limit of the Taylor remainder.
It is, however, the essentially the same as Fernando Revilla's suggestion in the first response to this thread.
The logic and context are not the same, as I was answering the question whether you can use the Taylor series. In general, you prove the validity of the Taylor expansion over a given interval by proving the Taylor reminder tends to zero as n goes to infinity. But here, because we can bring out a geometric series, as Fernando Revilla does in the initial answer, we have a simpler alternative. It is actually an exceptional case that is worth noting.
FAQ: Power series solution for Log(1+x)
What is a power series solution for Log(1+x)?
A power series solution for Log(1+x) is an infinite series of the form log(1+x) = ∑(n=1 to ∞) (−1)^(n−1) x^n / n. It is a way of representing the natural logarithm function as an infinite sum of powers of x. This series is valid for all values of x in the interval (-1,1) and can be used to approximate log(1+x) for other values of x.
How is a power series solution for Log(1+x) derived?
The power series solution for Log(1+x) can be derived using the Taylor series expansion of the natural logarithm function. By repeatedly taking derivatives of log(1+x) and evaluating them at x=0, we can find the coefficients of the power series. This results in the series mentioned in the answer to the previous question.
What are the advantages of using a power series solution for Log(1+x)?
One advantage of using a power series solution for Log(1+x) is that it allows for the approximation of log(1+x) for values of x outside the interval (-1,1). Additionally, the power series can be truncated at a certain term to obtain a more accurate approximation of the logarithm function. This method is also useful for solving logarithmic equations.
Are there any limitations to using a power series solution for Log(1+x)?
One limitation of using a power series solution for Log(1+x) is that it is only valid for values of x in the interval (-1,1). Outside of this interval, the series may not converge. Additionally, the accuracy of the approximation decreases as x moves further away from 0. This method also requires knowledge of calculus and the Taylor series expansion.
How can a power series solution for Log(1+x) be used in real-world applications?
A power series solution for Log(1+x) can be used in various real-world applications, such as in finance and economics, where the natural logarithm function is commonly used. It can also be used in physics and engineering to approximate various equations involving logarithms. Additionally, it can be used in computer programming to calculate logarithmic functions, as many programming languages do not have a built-in logarithm function.
